» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 03-11-2004, 02:29 PM   #1 (permalink)
Date registered: Feb 2004
Vehicle: 1979 300D, 1975 280C
W123 Mags on a W114
Hi Gang,
I recently purchased a 1975 280C and I found some W123 Aluminum wheels for a bargain ($120 for a set of four). They need to be repainted and I was wondering if anyone had some tips. Also, do they bolt right on, or do I need to make some adjustments?
Thanks in advance for all the help!
Cheers!
Alfred
alfredgee is offline   Reply With Quote
Old 03-11-2004, 06:04 PM   #2 (permalink)
E=MBČ
GermanStar's Avatar
Vehicle: GermanStar.net
RE: W123 Mags on a W114
I believe they'll bolt right up without a hitch.
German Star
GermanStar is offline   Reply With Quote
Old 03-11-2004, 06:36 PM   #3 (permalink)
Date registered: Dec 2003
Vehicle: 84 300D 84 240D
Lug bolt length might be different, check with a parts guy to make sure. Should fit otherwise.
Palangi is offline   Reply With Quote
Old 03-12-2004, 07:29 AM   #4 (permalink)
230Terry's Avatar
Date registered: Jan 2004
Vehicle: '98 E430 Estate, '90 190E, '55, 220a, '72, 280SE 3.5
If they have tyres on give them a good rub down to remove old paint and corrosion, smear the tire with a liberal amount of washing up liquid and spray paint. Saves messing about with masking tape etc. When dry overspray will wash off the tyre wall.
230Terry is offline   Reply With Quote
Old 03-12-2004, 02:10 PM   #5 (permalink)
Thanks for the response guys, they are not on tires so the painting process should be easier. I just need to spend some time prepping them. There is quite a bit of brake dust that needs to be scrubbed off.
I'll check with a parts guy on the lug length.
I look forward to having the mags on the car hopefully by summer and thanks again for the tips.
Cheers!
Alfred
Old 03-12-2004, 03:00 PM   #6 (permalink)
E=MBČ
GermanStar's Avatar
The lug length from W114 to W123 is the same, but the length is different when going from steel rims to mags.
Old 03-12-2004, 06:23 PM   #7 (permalink)
Hi Ron,
I'm not too technically savvy so forgive me. I have steel rims now so does that mean I need to get new lugs bolts?
Thanks!
Alfred
Old 03-12-2004, 09:51 PM   #8 (permalink)
E=MBČ
GermanStar's Avatar
alfredgee - 3/12/2004 6:23 PM
Hi Ron,
Thanks!
Alfred
Yes that's what it means. You'll need the standard mag wheel lugs, which are a bit longer than yours.
Old 03-12-2004, 11:02 PM   #9 (permalink)
Thanks for clarifying Ron.
All I have to do now is clean up the wheels for painting. Started today and 20 years of brake dust is a PIA to clean.
Thanks Again!
Alfred
Old 03-13-2004, 10:53 AM   #10 (permalink)
spsinha's Avatar
Date registered: Sep 2002
Vehicle: 2000 E430 4Matic, 1990 300E (sold)
Spray on some strong oven cleaner or use an SOS pad. Then give them a light sanding.
"Picture Me Rollin' In My 300 Benz"
spsinha is offline   Reply With Quote
