300SEL 3.5/4.5/6.3 Air Suspension - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 02-02-2004, 08:04 PM   #1 (permalink)
Date registered: Feb 2004
Is it possible to convert these suspensions back to the regular spring type taken off a 280SE/SEL? Anyone done this already? If so, how difficult? Thanks in advance.
lairtok is offline   Reply With Quote
Old 02-03-2004, 01:33 AM   #2 (permalink)
wbain's Avatar
Date registered: Dec 2003
Vehicle: 1965 220S, 1999 Volvo V70 (wagon), 2002 Ford Crown Vic Police Interceptor
RE: 300SEL 3.5/4.5/6.3 Air Suspension
Yes. You will also need the front suspension lower control arms. The originals are dished to make more room for the air suspension bits.
Are you having a 'problem' with the air suspension?
Near Manassas Va. '65 220S, 2002 Ford Crown Victoria Police Interceptor, 99Volvo V70
wbain is offline   Reply With Quote
Old 02-03-2004, 08:46 AM   #3 (permalink)
Typical problems.... after a week being parked, car looks like low-rider.....
Old 02-13-2004, 04:00 AM   #4 (permalink)
wbain's Avatar
Use the factory method, mix up a batch of soapy water, test each connection looking for soap bubles, replace the little tiny O-Rings. If there are leaks with the leveling valves, punt.
Old 02-21-2004, 11:12 AM   #5 (permalink)
i'm also interested in this topic. i am thinking that i might like to own a 300SEL, but the maintenance issues scare me a bit. chief among them seems to be the air suspension, and as above the main problem seems to be that it settles while the car is not running. is this really a functional issue, or does the inflation while the car is running compensate for the air loss?
i called a shop to inquire the cost of converting to springs and they are supposed to get back to me in a few days.
and while i'm at it, i'd personally love to hear any other comments about maintenance or ownership of a W109. cheers!
chizor is offline   Reply With Quote
Old 02-21-2004, 05:33 PM   #6 (permalink)
Date registered: Jan 2003
Vehicle: 67 300 SEL, 85 500 SEL, 90 420 SEL
Hi,
I've had my 67 300 SEL for 10 years now.
The only problem I've had with my suspension was the
right front valve. If I remember it correctly, it was
about $400.-- to replace it with a rebuilt one.
The supension is a dream. Even on the miserable bumpy
L.A. freeways the car drives perfectly. You would not
believe that you drive in an almost forty year old car.
Other than that it is not cheap to maintain the
109 with the M189 engine (3.0liter inline 6)
Parts are very expensive and sometimes hard to come by. I just had to get a waterpump from Europe, because nobody had one in the USA.
It is definitely cheaper to have the 3.5 liter or
4.5 liter.
I would always opt for a classic Mercedes with
air suspension and would never ever ever convert
one back to spring suspension.
Just my humble opinion.
Hans
Oceanside, CA
67SEL is offline   Reply With Quote
Old 02-22-2004, 09:33 PM   #7 (permalink)
Brian's Avatar
Not to knock the value of this forum, but you'll find much more information about the 300SEL air suspension issues here:
http://www.m-100.org/
http://www.m-100.info/cgi-bin/ibb/ikonboard.cgi
There is also a great air suspension trouble shooting guide here:
http://www.300sel.com/contact/contindx.html
Brian is offline   Reply With Quote
Old 02-27-2004, 10:51 PM   #8 (permalink)
wbain's Avatar
chizor - 2/21/2004 2:12 PM
The car will settle only if there is a leak. Fix the leak and it won't settle.
Old 04-20-2004, 08:28 PM   #9 (permalink)
4.5_sport's Avatar
Date registered: Apr 2004
Vehicle: 1994 E320T, 1979 VW Rabbit
Send a message via MSN to 4.5_sport
You could always convert to a modern air ride system. I will be undertaking this later this year on my steel sprung 4.5 .Check the street rod magazines or http://www.airride.com
4.5_sport is offline   Reply With Quote
Old 04-23-2004, 02:13 PM   #10 (permalink)
KyGuy's Avatar
Vehicle: '04 E500
Brian/all-
Good suggestion on the other M100 sites. I had an interesting problem with 6.3 in that it would stay up for a while (1-2 weeks)and then would settle over a couple days. My local wrench couldn't find any leaks after I'd done the basic DIY checks. I was noodlin' on the whole valve replacement issue and not liking it. On a flyer I took the car out a couple Sundays ago and put it in the high position and drove it slowly around my neighborhood for about 10 minutes. Paved streets but the valves had to work from this position. I then lowered it normal range and just drove, man. Came home and re-filled the condensation jar with de-natured alcohol (it was bone dry). It's been over 10 days and no settling at all. No scientific/mechanical basis for this, but it worked for me.
KyGuy
'04 E500 - Brilliant Silver/Grey - 70K miles
'01 ML320 - Desert Silver/Parchment - 83K miles
'01 C320 - White/Tan - 61K
'99 C230 Kompressor - Black/Black - 64K
'93 Mitsubishi Montero (Home Depot Express) - 131K
'70 300SEL 6.3 - Gold/Tobacco - 128K - Sold and returned to Germany
'94 E420 - Silver/Dark Blue - 80K - Sold
'97 E320 - Pearl Black/Parchment - 78K - Sold
'66 300SE Coupe - Gone and not lamented
KyGuy is offline   Reply With Quote
Bookmarks
