1964 230 sl Running Temperature - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-15-2002, 02:17 AM Thread Starter
Date registered: Dec 1998
Quoted: 2 Post(s)
Is it normal for the 230 sl be driven at temperatures above 90 deg C in heavy traffic in the summer. I've installed a much more efficient radiator (4 rows and high density fins) and with the 82 deg thermostat it scares me that the car continues to run above this temperature during the summer. I have an auxiliary fan and feel that the water pump fan is a little wimpy and this Model car 'starves' for air. Any help or modifications?
Guest (MBNZ) is offline
post #2 of 2 (permalink) Old 04-18-2002, 08:38 AM Thread Starter
Quoted: 2 Post(s)
Re: 1964 230 sl Running Temperature
Hey Mark,<br> <br> It is quite normal for these to run up to about 100C in heavy traffic in hot weather (depends on what you call hot weather though). Have you replaced the water pump? Perhaps it isn' t the radiator, but the fact that water isn't being circulated as efficiently as it should. Also, if you replace the water pump, check that the aluminium casing behind the pump is not too corroded, as this can make a good water pump inefficient.
