» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 11-21-2001, 07:17 PM   #1 (permalink)
Date registered: Dec 1998
380SL wheel bearing
Hi everybody,<br>
<br>
I am trying to replace rear wheel bearing for my 380SL. I got everything out but the inner bearing that attached to the hub flange. Does anybody know what tool I need to pull the bearing out and where to ger it, thanks.<br>
<br>
Kevin
Old 11-22-2001, 06:09 AM   #2 (permalink)
Re: 380SL wheel bearing
Kevin, I have never replaced a Merz bearing, however, if it is as most, you simply use a brass punch to hammer it out from the inside toward the outside. Does this not look it will work? You must be careful not to scar-up any machined surfaces. Sorry, I do not have actual Merz bearing experience.
