Hi there,
I've got a 2002 2.8 V6 Vito (W638 V280) for which the coolant fan hasn't been coming on, I've managed to get the fan to work by connecting it straight to the ignition live so know that part's ok.
I've tried replacing the relay and the thermoswitch but still nothing, eventually I took it to a garage that said it's the coolant fan control module. The part seems easy enough to replace but was quite expensive (over £400) so I've been looking for a 2nd hand unit.
The details on my unit are as follows
HKR GD AI S112 (CU)
System E 5002.001
I've looked online and the only ones I can find seem to be from the A-class and have different numbers on the casing, will this part still work or will I need the exact same numbers?
One of the listings i looked at also said I'd need to recode the new unit to work with my ECU (or something to that effect), is that true
Am i better off just forking out on the new unit?
Is there an alternative, it seems like an incredibly expensive way to just turn a fan on and off!
HKR GD AI S112 (CU)
System E 5002.001
