112 CDI Clocks Issues - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 08-20-2014, 08:41 AM Thread Starter
Date registered: Aug 2014
Vehicle: 2001 Vito 112CDI
Hi Guys
I know this is a repeated thread, and I've read most of whats around but here goes with my woes.
Not the original clocks mileage read 265,000. Last MOT before I bought it, the van was on 95,000 and 170,000 in 2 months is a bit of a push for any van!!!
1) Clocks turn themselves off every 5 seconds, only for a fraction of a second then return back to where they were. Everything works apart from speedo (see part 2) Occasionally they will just stop dead apart from the revs which will lock at about 1,000. Have to unplug at the back to reset back to "ticking" clocks. No beeping when lights on and doors are opened but rev counter will tick itself all the way round till it hits the stop.
2) Speedo has never worked from when I bought the van, previous owner said he changed the clocks to try and rectify this but to no avail. Was in the process of checking the sensor on the gearbox and tracing wires back only to find the yellow connector end of sensor cables under the dash not plugged in!! Hence why its not working. There is also another cable with a white connector not plugged in. Any ideas where these should plug in? The yellow/speedo cable is about 40-50cm to short to reach the clocks and obvious socket to connect to.
Any help on either of these issues would be much appreciated.
Fimpster is offline
post #2 of 14 (permalink) Old 08-21-2014, 01:19 PM
Date registered: Apr 2014
Vehicle: 2001 ml270 cdi auto
Hi ive had a fair bit of issues with the speedos so il give you what info i can.
Firstly even tho the speedo assembly may look to be the correct one, if it is not from the same model ie Vito 112 it will all work apart from the speedo, i know cos ive done it.
i got an identical looking speedo assembly from a 108 for my v220, all worked apart from speedo.
so i got a new repair kit from pixelfix, bit fidly to do but worked great,
You need a speedo from a 112, to start with, it must be from a 112 nothing else.
as for wires, my speedo assy has 2 block connectors thats all the clips in to the rear of dash.
hope this may help.
Len
pipetech is offline
post #3 of 14 (permalink) Old 08-26-2014, 10:57 AM Thread Starter
Hi Len
Thanks for that, I don't suppose you know part number for the 112 clocks, or have any idea where this yellow connector should plug in?
Thanks again Andy
Fimpster is offline
post #4 of 14 (permalink) Old 08-26-2014, 02:06 PM
il get the part number off my clocks tommorow.
And il have a look for a yellow connector and get back to you.
Cheers
Len
pipetech is offline
post #5 of 14 (permalink) Old 08-26-2014, 03:34 PM
Date registered: Aug 2013
Vehicle: V220
Quoted: 7 Post(s)
Sorry there but my v220 has clocks from a 110 cdi 99. everything works
Danny DeVito is offline
post #6 of 14 (permalink) Old 08-28-2014, 12:36 AM
Date registered: Nov 2013
Vehicle: V220 Ambiente W638 S500 W220 Land Rover Defender 110 TD5 Ford Puma 4X4 Cosworth Rally Car Fiat Scudo
Quoted: 118 Post(s)
I have edited this post, as it seems I may have been wrongly informed by other posts on this site.
Clock Sets with different part numbers may be able to be re flashed so they work with MB Star.
HTH
Cheers Dave
Dave2302 is offline
post #7 of 14 (permalink) Old 08-28-2014, 02:45 PM
Vehicle: V220
Quoted: 7 Post(s)
Originally Posted by Dave2302 View Post
The Auto Gearbox has speed sensors in it, whereas the Manual versions take their speed sensing from the ABS
Evidence please for education. I know the gearbox has many sensors but it still only throws it into the canbus. Why would they change the speedo 'feed' just because its auto ?
post #8 of 14 (permalink) Old 08-28-2014, 03:02 PM
Vehicle: V220
Quoted: 7 Post(s)
He lists a Vito 112 cdi. But i am confused. Are both plugs not attached behind the clocks ?
post #9 of 14 (permalink) Old 08-29-2014, 01:00 AM Thread Starter
Hi Danny, yes its a 112 manual. Both plugs are connected on the back of the clocks, and everything appears to work (when they are not switching themselves off every 5 seconds) apart from the speedo. The yellow connector runs from a sensor on the gearbox to the drivers side foot well, the cable is also well protected by aluminium sleeve (like a shower hose).
Fimpster is offline
post #10 of 14 (permalink) Old 08-29-2014, 01:44 AM
Quoted: 118 Post(s)
Hi Danny
It would appear that I may have been mis-informed or possibly I have mis-understood other posts on this forum.
Sorry
I read on here from Mark @ Vito spares that it is possible to have the clocks re flashed by MB Star machine so they can be interchanged, I don't now if this is true or not, but..................
This morning I installed the clock set I kept from the Manual Vito I broke up, (2003), into my V 220 CDI, (late 2002), and I can confirm everything including the speedo worked fine.
Both these clock sets had the same part number, but obviously different build dates.
HTH
Cheers Dave
Dave2302 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
