heater problems - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-07-2011, 05:08 AM Thread Starter
Date registered: Jul 2006
Vehicle: Vito 114 tourer 2015: Vito 108d 97: 108d 98: Traveliner 2003 ; Aixam; z1100; xbr500; z440 ++++
Quoted: 27 Post(s)
Exclamation heater problems
its cold, its icy................. brrrrrrrrrrrrrrr
I've been asked by several people about their heater not working (WHY Meeeee?)
No Blower, or Squealing Blower (you can hear its not running or making noises)
try the brushes in the motor.
Blower working but no hot air - little or no airflow, hot or cold
check Pollen filter not clogged, replace or remove filter if necessary
Blower working but no hot air - good airflow cold but not hot.
Check / replace heater bypass valve
Make sure your coolant is under 2years old or replace with 50/50 solution
Make sure your washer fluid is proper screenwash and strong enough to withstand freezing (you can easily drain by snapping out a washer pump)
File Type: pdf Removing and installing blower motor.pdf (70.8 KB, 1646 views)
File Type: pdf Removing and installing water bypass valve.pdf (79.3 KB, 1916 views)
File Type: txt 638 pollen filter 2.txt (340 Bytes, 1400 views)
malcolm@mill.me.uk is offline
post #2 of 13 (permalink) Old 11-09-2011, 01:12 PM
Date registered: Sep 2011
Vehicle: 110cdi Traveliner
Nicely volunteered Malcolm!
unfortunately, my issue not explained above!
Heater controls are just not working, I suspect (know!) that the control cables are shot. Doesn't matter where I put the vent direction control, air always comes out of the center dash vents
I've had the dash panel out and can see the two wheels at the top of the control unit that counter rotate and one of the cables has bent (probably due to stiffness at the other end) This is the same with the one that controls the hot water valve that sits above the brake pedal on the bulkhead.
I don't know why this has happened...
I also can't find any reference to these cables in the WIS anywhere either?
Any advice greatly appreciated as always!
Gandhi is offline
post #3 of 13 (permalink) Old 11-09-2011, 09:35 PM
Date registered: Jul 2007
Vehicle: 2016 Vito 116 Bluetec
Quoted: 6 Post(s)
Hi Malcolm,
A few months ago, my heater core died (water all over my feet) and I'm looking to replace the heater core.
I have been told that I need to remove the entire dash in order to take it out and replace.
Any chance you have a diagram on where all the screws/bolts, etc are for removal ?
Also, I found a copy of WIS and have tried to use it but can't seem to. The version I found came with 4 dvd's. Maybe PM me about it ?
Thanks,
Sam
mr_v8 is offline
post #4 of 13 (permalink) Old 11-10-2011, 07:32 AM Thread Starter
Quoted: 27 Post(s)
Gandhi..... I've had the problem in other vehicles, the cable jam is normally caused either by a bit of grit on the cable, often caused by someone putting oil on a cable that shouldn't be oiled which becomes sticky and grit sticks to it, OR by the flap sticking.......... someone then uses force on the control and the cable kinks... once the process starts it just gets worse until it jams...... I will see if I can find any details later (after my medication kicks in)
mr v8,,,,, I will get you the available information later (as above..... when my drugs kick in)
for your WIS problem see WIS Problem in forum listing.
post #5 of 13 (permalink) Old 11-10-2011, 11:25 AM Thread Starter
Quoted: 27 Post(s)
Heater PDFs as promised
all options covered from adjusting vents to dismanting entire front end (I think)
Please Note:
thanks to MB being German and all documents are therefore translations, MOST drawings show Left Hand Drive..... apart from steering wheel position, there are no differences to a Right Hand Drive model.
ALSO: terminology in WIS/EPC may not translate how you expect e.g. look up "heater" and a brit expects the thing that blows hot air at the driver..... in fact its an auxiliary diesel powered unit.
The "heater" is either "climate control" "ventilation" or "blower"
GOOD LUCK especially if you want to take the heater core out.
post #6 of 13 (permalink) Old 11-10-2011, 01:15 PM
Quoted: 6 Post(s)
Yeah.... I thought removing the heater core would be way too much fun
mr_v8 is offline
post #7 of 13 (permalink) Old 11-10-2011, 02:00 PM
Quoted: 6 Post(s)
OH... you forgot to attach the documents Malcolm..
Sam
mr_v8 is offline
post #8 of 13 (permalink) Old 11-10-2011, 03:28 PM Thread Starter
Quoted: 27 Post(s)
No I didn't................ I'm perfect (or something like that)
I uploaded the PDFs but they don't seem to have made it..........
Here I try again
post #9 of 13 (permalink) Old 11-11-2011, 01:32 PM
Date registered: Nov 2011
hi,im new here so please accept my appologies for giving you another problem with heaters.mine is not in your quotes,i have just bought a 52 plate vito 108cdi with 143k on clock.the heater seems to work ok apart from it is noisey,it sounds like a boy racers exhaust on full.any ideas what this is and how to solve it please.thanks
outofdarkness is offline
post #10 of 13 (permalink) Old 11-12-2011, 01:02 AM
Date registered: Jan 2009
Vehicle: Vito 3.0 V6 Silver
My pollen filter was clogged up and the fan was really noisy, removed the filter and noise was gone.
moog is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
  • Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
    heater problems, please help!! colin_397 W202 C-Class 1 03-07-2010 01:41 PM
    Heater problems! Too hot!! thewhisperingone W168 A-Class 0 03-29-2008 06:08 AM
    heater problems badassb Vintage Mercedes-Benz 2 07-30-2007 10:15 AM
    Heater Problems MB-Owner-in-ind W123 E,CE,D,CD,TD,TE Class 11 08-01-2005 04:52 PM
    heater problems Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 03-22-2001 07:20 PM
