V220 Idle adjustment - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-26-2010, 06:04 AM Thread Starter
Shoboshi's Avatar
Date registered: Oct 2010
Question V220 Idle adjustment
Hi Guys
New to the forum and have tried searching for idle speed adjustment for 1999 V220 Diesel but no luck so far. Can any one enlighten me as to what the idle speed should be and how to raise it?
Many Thanks
Shoboshi
Shoboshi is offline
post #2 of 7 (permalink) Old 10-26-2010, 09:54 AM
Im new to and I wrote few messages on the thread "Vito-Fumes in cab" coz I have this problem that I found outis called Black death. I have also V220 and also I weant to adjust the idle.I also want to raise I think is done by chipping but not sure.
DarioMusic is offline
post #3 of 7 (permalink) Old 10-26-2010, 11:55 AM
Ive adjusted my on the pedal end unsure if this is correct but it worked for me
muply is offline
post #4 of 7 (permalink) Old 10-28-2010, 10:20 AM Thread Starter
Shoboshi's Avatar
Thanks I'll give it a try.....
Shoboshi is offline
post #5 of 7 (permalink) Old 10-30-2010, 10:45 AM
Custom Chris's Avatar
Date registered: Jun 2009
Vehicle: Vito 110 CDI Mapped, 6 Seater, 18's, Zorst, Heavy ICE, Xenons
You can't adjust the idle speed as such on these it's all controlled by computer. If it's too low, something else is wrong.
Vito Forum
Bringin the beast back from the dead
Custom Chris is offline
post #6 of 7 (permalink) Old 10-31-2010, 09:46 AM Thread Starter
Shoboshi's Avatar
Thanks for the reply.
I asked my local dealer who said the same thing.
I did raise it slightly by taking up slack on the throttle cable, not a huge amount but enough to stop the rumble.
Thanks again.
Shoboshi is offline
post #7 of 7 (permalink) Old 11-01-2010, 04:29 AM
Getting rid of the slack is a winner for better throttle response.
Vito Forum
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
    idle adjustment hlc W124 E,CE,D,TD Class 1 10-11-2010 08:10 PM
    idle adjustment Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 12 11-01-2009 08:30 AM
    Idle Adjustment jlechmann W123 E,CE,D,CD,TD,TE Class 5 08-20-2009 07:03 PM
    idle adjustment. benztece W124 E,CE,D,TD Class 18 04-19-2006 06:14 PM
    Idle adjustment and Thank You!!! izeljic W123 E,CE,D,CD,TD,TE Class 2 06-05-2003 06:09 AM
