vito brake lights - relay??? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 06-19-2010, 12:06 PM Thread Starter
Date registered: Jun 2010
Hi
Both my rear brake lights are not working (not ideal) - it is deffinitly not the bulbs, pretty sure it isn't the switch and my friend tells me he had something similar with his VW and it turned out to be the relay.
Only problem is I have no idea which relay controls the brake lights (if indeed there is one). It is a RHD 108D 1998.
Any help would be appreciated.
Kev
KevM17 is offline
post #2 of 6 (permalink) Old 06-19-2010, 01:46 PM
Custom Chris's Avatar
Date registered: Jun 2009
Vehicle: Vito 110 CDI Mapped, 6 Seater, 18's, Zorst, Heavy ICE, Xenons
Check the switch at the top of the pedal
Custom Chris is offline
post #3 of 6 (permalink) Old 06-19-2010, 01:48 PM
Are your normal lights working?
Vito Forum
Bringin the beast back from the dead
post #4 of 6 (permalink) Old 06-19-2010, 03:54 PM
adamuk's Avatar
Date registered: Apr 2006
Vehicle: Vito 111CDi 2004
What Vito do you have? If you have a W638 then it could be a relay. Things are a little more complicated in the W639 as it's all controlled by the signal aquisition module (SAM)
Adam.
adamuk is offline
post #5 of 6 (permalink) Old 06-23-2010, 12:39 PM Thread Starter
Thanks for the advice - the switch looks fine (I actually bypassed it and it still didn't work). I'm not too sure about which type it is - I know it as a 108D - made in 1998.................
looked under the seat next to the battery and it appears to have several small black boxes there - I think these are relays - but obviously I have no idea which one is which to try and replace one...........
KevM17 is offline
post #6 of 6 (permalink) Old 08-25-2010, 10:52 AM
VitoMike's Avatar
Date registered: Aug 2010
I got exactly the same problem. Where could the relay be located and how can I distinguish it?
(right now there is no brake lights, brake swich and all other lights are working and when I checked brake wires from brake swich there is voltage in these wires, 0,5V, and when I measured amperage, there was 0,6A current...strange)
VitoMike is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
    BAS/ESP/ABS lights on and brake lights don't work laurentiu1 W210 E-Class 39 01-13-2014 08:09 AM
    ABS/BAS-ESP lights on - Brake lights don't work niwred W210 E-Class 12 11-27-2013 04:53 AM
    2001 Vito horn relay (which one?) grabs V-Class 1 04-05-2010 01:48 PM
    brake relay? soulsociety714 W163 M-Class 3 12-15-2007 08:48 PM
    SLK R171 Tail Lights and Centre Brake Lights for Sale slkfans For Sale/Wanted/Trade/Giveaway 0 01-22-2006 11:20 AM
