2003 110 CDI P1470 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-08-2010, 01:17 PM Thread Starter
Date registered: Aug 2006
Vehicle: 99 VITO 95C280 04 C55
2003 110 CDI P1470
P1470 Charge Pressure Control This fault code comes up only at 100km/h.Stop,turn off ignition,restart OK again until 100 is reached.Can drive in low gears up to 5k rpm no problem.We have tried a known good control valve but no difference. I have hada search around,anyone have any ideas.Cheers
ROBERT
karmobRob is offline
post #2 of 6 (permalink) Old 05-08-2010, 01:29 PM
Date registered: May 2010
Mercedes-Benz Sprinter CDI van, code P1470. - Forums
http://www.justanswer.com/questions/...-merc-sprinter
have you checked actuator on turbo is moving when revving engine
not 100% but think actuator stops overboost which means if actuator is no good
or there is a vacuum leak , engine will go into safe mode when detecting to much boost.
hybriduc is offline
post #3 of 6 (permalink) Old 05-09-2010, 09:48 PM Thread Starter
Thanks for the quick reply,will check. We are getting 4psi boost maximum which I think is a bit low.But not sure what it should be.
post #4 of 6 (permalink) Old 05-19-2010, 10:47 PM Thread Starter
Yes,actuator arm moves OK
post #5 of 6 (permalink) Old 05-20-2010, 03:58 AM
not 100% on this one but someone on forum was getting 15psi or 1.0 bar max boost
marc
hybriduc is offline
post #6 of 6 (permalink) Old 05-22-2010, 12:52 PM Thread Starter
Yes,that sounds about right.Problem solved,removed top intrcooler hose and a split underneath.New hose done.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
52 plate 2003 vito van 110 cdi mercsl320 V-Class 18 08-22-2013 05:42 AM
110 cdi rufflesurf V-Class 0 10-20-2007 02:41 AM
Vito 110 cdi . Help please GEO Prep V-Class 11 09-02-2007 07:30 AM
52 plate 2003 vito van 110 cdi mercsl320 General Mercedes-Benz 0 06-26-2007 03:05 PM
question on 110 CDI alexng V-Class 0 08-19-2005 08:47 AM
