I made this from a wire shoe brush so its a soft brush and therefore won't scratch , it will just clean injector seat. there is a copper outer sleeve which you use to position the wire brush into the correct place, then you pull up the copper outer tube and twist the wire brush to clean with WD 40.
The bristles have been properly secured and drilled and glued into the wooden dowel.
If enough people want to buy one then I may sell them.
I made it to clean my Vito injector seat after several failed attempts at sealing an injector onto a dirty seat.
:thumbsup:
:thumbsup:
