110CDI Thermostat - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-01-2009, 01:55 PM Thread Starter
Date registered: Aug 2009
Vehicle: 2001 110CDI
110CDI Thermostat
how easy is it to replace thermostat on 2001 110cdi ?
phil998s is offline
post #2 of 7 (permalink) Old 12-02-2009, 11:42 AM Thread Starter
Surprised no-one knows
phil998s is offline
post #3 of 7 (permalink) Old 12-02-2009, 02:45 PM
walsi's Avatar
Date registered: Mar 2007
Vehicle: 2000 108CDI, 2007 120 CDI long, Suzuki K5 GSXR track bike, 2005 Kawasaki ZX10R
Maybe its the one bit on a vito that is reliable and well made, miracles do happen
walsi is offline
post #4 of 7 (permalink) Old 12-03-2009, 12:25 AM
Date registered: Sep 2006
Vehicle: W639
Quoted: 5 Post(s)
There's plenty of info if you search.
This thread might help
http://www.benzworld.org/forums/v-cl...gine-temp.html
Here's my post with fitting details
http://www.benzworld.org/forums/v-cl...ml#post3499096
darkside is offline
post #5 of 7 (permalink) Old 12-03-2009, 12:35 PM
Date registered: Jan 2009
Vehicle: 110cdi vito 8 seater
For the record my replacment thermostate is still in the box! (see linked thread). I will fit it soon...
dieseljo is offline
post #6 of 7 (permalink) Old 12-03-2009, 03:40 PM Thread Starter
Gauge goes to 50 and holds there should be in low 80's may be reliable but to low
phil998s is offline
post #7 of 7 (permalink) Old 12-13-2009, 03:06 PM
jonny rash's Avatar
Date registered: May 2009
Vehicle: 2000 Vito 110CDI (never should have sold it), Current project 1999 V220 Ambient
It is a very simple job really.
Remove the grill for easier access. Remove the intercooler pipes. Remove the water pipe which is connected to the thermostat (you will lose some coolant here so don't do this after you have removed the oil filter)
Remove the oil filter and fill the hole with a clean rag. As far as I remember the thermostat is held on with 3 bolts (maybe they are torx type which will be annoying if you don't have the right tools) You will need to carefully remove a fuel line bracket and slide it to one side so you can slide the thermostat straight out. Don't forget to unclip the electric connector.
Getting the new thermostat in is slightly fiddly (make sure the old o-ring comes off and the new one stays in place) and now it is just a case of putting everything back.
Don't forget to put the cab heater on full, run the engine and top up the coolant, while you are at it, check for leaks where you have been working. It is better to notice now than later on
Name:	remove grill for access to thermostat.jpg
ID:	279089   Click image for larger version
Name:	new thermostat fitted.jpg
jonny rash is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
    vito 110cdi 2000 help please khan_uk0 V-Class 13 06-23-2009 05:41 PM
    Gear linkage on 110CDI Curly68 V-Class 0 06-13-2008 02:52 PM
    vito 110cdi 9 seater vitocabman1973 V-Class 2 01-20-2008 04:16 PM
    110cdi For Sale andyvito V-Class 1 05-19-2007 12:11 PM
    110cdi lights ayjay V-Class 3 10-30-2006 06:18 AM
