Wont rev past 3000 at idle?? 110 cdi - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-22-2009, 09:01 AM Thread Starter
Date registered: Nov 2009
Hi all,
I have been working on the van most of the day today cleaning inside and out. I had the engine running for around 20 mins when it got dark so I could have the rear lights on in the back without the risk of flattening the battery. When I had finished I reved the van up a little bit as to make sure the battery had some beans and found it wouldnt rev past 3000 rpm. Is this normal? There were no warning lights on the dash etc. The van was idling at the time when I reved it. The van is a 110 cdi vito 1999 any advice appreciated. Cheers Paul.
VitoOgg is offline
post #2 of 9 (permalink) Old 11-22-2009, 10:18 AM
Matelot's Avatar
Date registered: Mar 2007
Vehicle: 1999 108 Cdi Traveliner, 1999 V220 Cdi, 2003 V220 Cdi
Hello Paul.
As far as I'm aware there's a safety interlock that prevents you over revving the engine when at a standstill (linked to the handbrake, I think).
Take the van for a spin to see if it revs past 3000rpm. If it doesn't then you're in limp mode & will have to do some head scratching to reveal what's caused it.
If it revs freely then you've nothing to worry about!
Hope this helps.
Good luck,
Rob
Matelot is offline
post #3 of 9 (permalink) Old 11-22-2009, 12:19 PM
jimbrodie1's Avatar
Date registered: Aug 2009
Vehicle: Vito 110 CDI Travelliner
Yep perfectly normal.
You'll have fun when you go for an MOT as well when they try and rev it up for the emissions test
jimbrodie1 is offline
post #4 of 9 (permalink) Old 11-22-2009, 12:27 PM Thread Starter
Thanks guys never had a vito before always wanted one so getting used to the quirks etc, gonna be a project vehicle, my daily driver and work van all in one so got loads of plans etc am looking forward to it it was a back up recovery van so has all the kit for starting vehicles etc and the amber lights on top (dont know if I should keep them on or not??) bit of rust not as bad as some I will take some picks and do an introduction thread soon but as always I have started work on it before I have taken the first pic Cheers Paul.
VitoOgg is offline
post #5 of 9 (permalink) Old 11-25-2009, 02:27 PM
vito-sam's Avatar
Date registered: Oct 2009
Vehicle: 2003 Vito Traveliner 108CDI
yeah completely normal. i think if you press/depress the clutch then you can rev it over 3k
vito-sam is offline
post #6 of 9 (permalink) Old 11-27-2009, 01:03 PM
Date registered: Feb 2008
Vehicle: vito 120 cdi
as the germans would say 'why would you want to rev it above 3000rpm'?
steel-jaw-sasha is offline
post #7 of 9 (permalink) Old 07-26-2011, 08:00 AM
Date registered: Jul 2011
Thanks for this advice, what would I do without this forum. One of the best forums out there. Cheers guys
w33ksy is offline
post #8 of 9 (permalink) Old 07-26-2011, 02:54 PM
Vehicle: 2001 silver vito 108cdi intercooled and with reversing sensors
correct
R.V.S.MOBILE.MECHANICS is offline
post #9 of 9 (permalink) Old 11-09-2011, 06:31 PM
Date registered: Oct 2010
CDi Accelerator pedal issue
I'm new to this forum but i will try my luck if i can get advices from you guys.
I have my CDi 110 for 3 years now, and it clocks at 56,000kms. I had minor problems before as you did with yours, but in the last 2 weeks now, i'm having a new one, the throttle seem to cut off from time to time but not in a regular manner, the engine idles even when driving at any speed, no matter how you step on the pedal it won't accelerate and the rev meter remains at idle. I stop and put the gear to neutral and then to drive, and it goes back as if nothing happened. The mechanic said, its the accelerator pedal switch which has to be replaced.
DocGT is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
vito 108 cdi wont rev over 3000rpm tripod23 V-Class 4 11-19-2011 03:48 AM
C230 Reduced Power/Wont rev past 4200? rodcam W202 C-Class 10 05-27-2009 10:47 PM
110 cdi wont turn over help!!!! rchceramics V-Class 6 04-07-2009 04:31 AM
S 140 wont rev past 4000prm ..WHY ??after i washed engine!! S3201994 General Mercedes-Benz 2 05-24-2007 04:19 AM
S 140 wont rev past 4000prm ..WHY ??after i washed engine!! S3201994 W140 S-Class 9 05-23-2007 05:55 PM
