Vito 109cdi Ignition/key problem - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-28-2009, 12:18 PM Thread Starter
Date registered: Apr 2009
I have a Vito 109cdi and it has what I can only describe as an electronic key, it is plastic and has three buttons on it. The end of the key inserts into the ignition barrel on the dash which is all plastic.
Normally when the key is pushed into the barrel the ignition lights illuminate and then the key can be turned to switch the ignition on and then start the vehicle. The only problem is that when I push the key into the barrel nothing happens it does not do it all the time though! I have to remove the key from the barrel and push it in the barrel hard, several times. On some occasions it has taken me 5-10 minutes before the key has worked.
Does anyone have an idea of what could be wrong?
Thanks in advance
chez
chez is offline
post #2 of 8 (permalink) Old 04-28-2009, 01:54 PM
Date registered: Sep 2007
Hi Cez
I have heard this can be a problem on the new vitos , I was told it can take 4- 5 days for MB to get a new key and code it.
sorry I can't be more help.
Pablo
pablo2 is offline
post #3 of 8 (permalink) Old 04-28-2009, 01:59 PM Thread Starter
Thanks for the reply.
If it is just the key that needs replacing then it is not too bad, I was thinking it could be the immobiliser or ECU.
I think it is less than £200 for a new coded key, which is much cheaper than what I was expecting. It's of course still a massive rip off for a bloomin key though!
chez is offline
post #4 of 8 (permalink) Old 04-28-2009, 02:29 PM
Date registered: Aug 2007
Hi
Change the batteries, check your owners manual how to do it...
vitofin is offline
post #5 of 8 (permalink) Old 04-28-2009, 11:19 PM Thread Starter
Originally Posted by vitofin View Post
Hi
Hi, I have already changed the remote batteries and it never made any difference at all.
Thanks chez.
chez is offline
post #6 of 8 (permalink) Old 05-03-2011, 01:13 PM
Date registered: May 2011
Unhappy
Hi this exact problem happened to mine I left it and left it as it was an intermittent problem but then left me stranded.!! Only main deal can carry out the repair and it's the ignition barrel/key reader that became faulty they need Mercedes specific coding!! Expect to pay around £800-£1000 mark the parts alone are very expensive which bumps the cost up :-/
Purdupug is offline
post #7 of 8 (permalink) Old 05-03-2011, 01:36 PM
Date registered: May 2010
Quoted: 8 Post(s)
Mate, That was 2009...
I can replace all EIS/EZS with used or new without anything to do with Mercedes Benz!
Mark@Vitospares is offline
post #8 of 8 (permalink) Old 05-03-2011, 02:14 PM
s2vto's Avatar
Date registered: May 2008
Vehicle: Mercedes Vito Dualiner 2005
Send a message via MSN to s2vto
2005 109 Vito Dualiner, Carbon Metallic Black, Comfort Letherette seats, custom interior...
s2vto is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
    '86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190-Class 7 04-13-2010 03:35 PM
    Vito 109cdi owner chez General Mercedes-Benz 2 08-10-2009 11:46 AM
    Vito 109CDI: Oil on turbo and resetting brake warning petter78 V-Class 2 12-10-2008 02:05 AM
    Vito 109cdi 2000 Model JCSMOTO V-Class 3 05-15-2007 12:33 PM
    ignition/key problem 5410yc G-Class 3 02-01-2007 12:06 PM
