Engine temp. - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 01-04-2009, 12:35 PM Thread Starter
Date registered: Jan 2009
Vehicle: 110cdi vito 8 seater
Engine temp.
Hi owned my 02 110cdi a while now but just noticed that engine temp rarely seems to get above 65 in the cold weather. Im thinking that the thermostat is at fault, but i havn't had a chance to look at it yet to confirm this. However could anyone tell me where its located on the engine? and how easy it is to change as i was going to renew the coolant soon anyway.
dieseljo is offline
post #2 of 22 (permalink) Old 05-04-2009, 06:29 AM
Date registered: Sep 2006
Vehicle: W639
Quoted: 5 Post(s)
Did you manage to sort this out? Was it the thermostat (and where is it!?)
My engine temp only hits about 65, I'm sure it used to hit 80 so am suspecting my thermostat. I'm due a coolant change too.
darkside is offline
post #3 of 22 (permalink) Old 05-04-2009, 10:51 AM Thread Starter
No still hovers around 70 on a run even now its warmed up outside. I bought a thermostat awhile ago, when the gear change cables went. It just over £30 if i remember correctly. The thermostat is located to the left of the engine as you look from the front of the van under the fuel filter. Looks like a pig to get to! I havn't been brave enough to meddle just yet as i read a few horror storys on here when fuel filters are disturbed.
dieseljo is offline
post #4 of 22 (permalink) Old 05-04-2009, 10:56 AM Thread Starter
Oh forgot to say its held in place with multi pointed fixing bolts, but i think a 10mm socket will get them undone if there not to tight ( havn't tried mine so dont know). All in all van runs ok low 30s mpg heater warms up in the end so didnt want to cause further problems. If i fit it one day i will report back.
dieseljo is offline
post #5 of 22 (permalink) Old 05-04-2009, 11:19 AM
Hodgy's Avatar
Date registered: Oct 2008
Vehicle: Vito 108cdi
The fixings are Torx bolts, the correct sockets can be got from Halfords if there too tight to get off
Hodgy is offline
post #6 of 22 (permalink) Old 05-04-2009, 02:10 PM
Vehicle: W639
Quoted: 5 Post(s)
I was after doing a fuel filter so could have a crack at the thermostat while I'm in there.
Hopefully it's a DIY job once the fuel filter is out?
GSF list one at £6 odd, europarts at £31! I'll pop to GSF and check it out.
darkside is offline
post #7 of 22 (permalink) Old 05-06-2009, 07:43 AM
Vehicle: W639
Quoted: 5 Post(s)
I've cracked and am sticking mine in the garage tomorrow for a check. They're going to inspect the thermostat while the swap the filter for me.
darkside is offline
post #8 of 22 (permalink) Old 05-07-2009, 08:29 AM
Vehicle: W639
Quoted: 5 Post(s)
Hopefully not talking to myself here!
Anyway, in my case, garage confirmed it's not the thermostat. The 'stat is opening the water getting to the right temp.
So it's the sensor or the actual dash dial.
Anyone know if I can borrow a mate's dash and plug it in? That should let me check if it's the dial!
darkside is offline
post #9 of 22 (permalink) Old 05-07-2009, 09:36 AM Thread Starter
I did wonder if it was my sensor and dial playing up as hot air blower warms up quite quick for a diesel. The sensor comes complete with the thermostat and housing case which is why it so expensive. I think the dash has to be coded to the van but temp dial may work regardless im not sure.
dieseljo is offline
post #10 of 22 (permalink) Old 05-07-2009, 02:50 PM
Vehicle: W639
Quoted: 5 Post(s)
If the sensor is faulty, would it just mess with the dial on the dash or affect the fueling as well?
If it's just reporting wrong, it can stay wrong but if it's running wrong, I would like to fix it!
darkside is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
A/C and Engine Temp. redbeast R129 SL-Class 26 06-25-2008 08:22 PM
Engine Temp beno C208/A208 CLK-Class 4 12-13-2007 11:10 PM
Engine Temp sciroccin W163 M-Class 1 07-05-2006 05:33 PM
Engine temp ilong_99 W202 C36 AMG, C43 AMG 1 09-22-2003 07:09 AM
Engine temp. sjtymko W123 E,CE,D,CD,TD,TE Class 5 05-28-2003 06:56 PM
