Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 07-17-2008, 03:26 PM   #1 (permalink)
mattp94's Avatar
Date registered: Jan 2005
Vehicle: Vito 110CDi
Brake warning light
I had the front discs and all brake pads replaced about a month ago when I had my 110 CDi serviced. I then drove down to the Alps and after coming down a particularly long steep path from Alp D'Huez the brake warning light came on. It now comes on and stays on as soon as I touch the brakes. Assuming that the new discs and pads were all correctly fitted (the brake still work just as well as always) does anyone know what could be causing this?
Appreciate your suggestions.
Cheers
Matt
mattp94 is offline   Reply With Quote
Old 07-18-2008, 01:06 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: v220 ambiente
Check pads in case warning light is correct and one or more pads actually have worn down! This might be because a calliper has been sticking on. Otherwise most likely a wire to the sensor in one of the pads is broken and touching the chassis somewhere. However this usually gives intermittent or constant warning independent of brake application.
G
grav220 is offline   Reply With Quote
Old 07-31-2008, 06:42 AM   #3 (permalink)
Date registered: Jun 2007
mine flickered on and off for a while then dumped all the fluid out of a pipe fixed to the back axle.
worth checking
firstchase is offline   Reply With Quote
Old 07-31-2008, 02:04 PM   #4 (permalink)
mattp94's Avatar
Thanks for your replies. I've had the brakes off and found the problem. It wasn't a wear sensor after all. It would appear that racing your mate ( in a VW tansporter) down an Alp is actually a very effective way of wearing out your nearly new brake pads within the space of just 20km or so. In their defence, I was hauling about 1/2 tonne of gear in the back and descending nearly 2km vertically down over some 21 hairpin bends.
Lesson learned, I'll be more careful next time.
Old 08-09-2008, 08:12 AM   #5 (permalink)
Date registered: Aug 2008
Did you win the race?
I wouldbe a bit cranky if I wore outmy brakrs and lost.
Regards Whitworthsocket
whitworthsocket is offline   Reply With Quote
Old 08-09-2008, 08:21 AM   #6 (permalink)
mattp94's Avatar
Of course, by about 500m. ;-)
Old 08-09-2008, 08:39 AM   #7 (permalink)
Well done.It was all worthwhile then.
I hope that you never let him forget.
Brake Warning Light On faithern R170 SLK Class 11 06-13-2007 09:20 AM
brake warning light gregp3 General Mercedes-Benz 1 05-23-2006 04:21 PM
Defective Brake light bulb warning light fggonzales W124 E,CE,D,TD Class 0 08-06-2004 04:50 PM
Brake warning light came on jay (new jersey) R170 SLK Class 3 06-04-2003 11:28 AM
Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK Class 3 03-21-2001 03:28 PM
