» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 07-04-2008, 07:20 AM   #1 (permalink)
Date registered: Apr 2008
intermittent gearbox problem
Last week my battery went flat because the boot wasnt closed properly and all the interior lights were on all night, now after charging and putting the battery back in i am getting an intermittent gearbox problem. The gearbox light will flash to let me know there is a problem, if i try to start it anyway the car just stalls again, but if i turn the ignition off and on a few times the gearbox is fine. Anyone had this problem or can point me in the right direction for a fix? Cheers
Widget is offline   Reply With Quote
Old 07-25-2008, 01:53 PM   #2 (permalink)
Date registered: Oct 2007
have had the same problem, turned out to be the throttle body - not cheap though £495 + Vat
r.uppal is offline   Reply With Quote
Old 07-28-2008, 08:00 AM   #3 (permalink)
DYB
Date registered: Feb 2008
Yep, it turned out to be a short circuit in my starter wiring. After I rewired it, everything went OK.
DYB is offline   Reply With Quote
Old 07-28-2008, 09:58 AM   #4 (permalink)
Can you please advise me on what and how you rewired it and i will have a go. Cheers.
intermittent electrical problem Ko-Ko-Klown W124 E,CE,D,TD Class 4 07-02-2008 12:40 PM
4 matic intermittent problem jackrabbit W124 E,CE,D,TD Class 3 01-03-2008 06:28 AM
intermittent wiper problem Mike Wevrick General Mercedes-Benz 14 10-13-2007 05:34 PM
Intermittent starting Problem Hopeless W126 S,SE,SEC,SEL,SD,SDL Class 6 02-25-2006 11:51 AM
Intermittent Idle Problem Pistolero63 R129 SL Class 1 12-15-2005 07:50 PM
