» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 07-01-2008, 03:55 PM   #1 (permalink)
Date registered: Jul 2008
Vehicle: 108 cdi w reg
Post 108cdi lack of power
hi all just bought a w reg 108cdi, van is great, but seems really underpowered, just had injectors done, new radiator, put new radio in and now heater blower not working was fine before,any things to check on van, also when you drive the van, from inside you can really hear air being sucked in somewhere, not to sure whats happening,it sounds like a whistle,my 13 year old son thinks it sounds cool,lol,bu i am a bit worried,any suggestions would be very helpfull. also jut ordered new speedo clocks from dronsfields today,150 plus vat, thought that was good price,cheers
freddyone is offline   Reply With Quote
Old 07-01-2008, 07:29 PM   #2 (permalink)
tonto555's Avatar
Date registered: Apr 2008
Vehicle: 2000 Vito 108 cdi
Send a message via MSN to tonto555
When you open the bonnet there is a rubber pipe just beneath the wiper in the middle, check that this is connected securely. I had a whistling sound before but only when excellerating. this pipe had come loose and once replaced sound disappeared.
May not be your problem as Ive read other threads about Wipers, Window Trimmings all making noise. Check all the windows are closed properly, sounds idiotic but if you only drive the van you never think of the passenger side window being slightly open.
tonto555 is offline   Reply With Quote
Old 07-02-2008, 10:48 AM   #3 (permalink)
hi thanks for that will check pipe later, put new clocks in today and van wont rev over 3000rpm,
Old 07-07-2008, 05:56 AM   #4 (permalink)
Date registered: Nov 2007
I think you may have lost your boost presure check under the engine at the rear there is a metal pipe runs from the front of the engine to the rear then a rubber pipe attached to it check the rubber one that it is not split as this happen's a lot on the vito's and makes the sound that you hear and you also lose power.
T22TAD is offline   Reply With Quote
Old 07-08-2008, 05:35 AM   #5 (permalink)
Date registered: Jun 2008
Had a similar problem and it turned out to be a split booster hose. 3000rpm when warm was when I would lose turbo boost and it would be absolutely gutless. (the hose apparently opened up enough when it was hotter to bleed air), when cold it was happy as larry for about 15 minutes.
small problem in the end...
gf0012-aust is offline   Reply With Quote
108CDI slow to power on start up fangfromoz V-Class 4 03-09-2008 12:45 AM
LACK OF POWER PLEASE HELP AMG_BLACK R230 SL Class 5 09-17-2007 03:25 PM
LACK OF POWER PLEASE HELP AMG_BLACK W211 E-Class 0 09-16-2007 01:18 AM
Serious hesitation and lack of power..... omeyhomey W210 E50 AMG, E55 AMG 18 09-04-2006 04:41 PM
108cdi, lose of power during cruise [intermittently] mowingvito V-Class 1 04-19-2005 03:06 PM
