Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 06-24-2008, 10:24 AM   #1 (permalink)
Date registered: Jun 2008
heavy duty vito springs ? ( rear )
Do they exist or are they all the same. (1998 van ) , if so part no's please.
Paul
Paul02 is offline   Reply With Quote
Old 06-25-2008, 02:09 AM   #2 (permalink)
Benz Bling's Avatar
Date registered: Sep 2004
Vehicle: Vito 113
Paul
Hi Paul,
If you are after some genuine Mercedes-Benz rear suspension (springs and dampers) for a W638 Vito, I have some for sale. It came off my Vito and has only covered approx 1,000 miles, it was removed by Demon Tweeks when they fitted a set of H&R lowering springs and Koni uprated dampers (shocks).
If you are interested drop me a private message and we can discuss a price.
Regards,
Benz Bling
It’s all about the style!
Benz Bling is offline   Reply With Quote
Old 06-25-2008, 11:14 AM   #3 (permalink)
Thanks Benz
Maybe the same as what I already have , I need to know the answer to the above question first and if the answer is yes then I need to hunt down a pair of HD springs.
Paul
Old 06-25-2008, 11:08 PM   #4 (permalink)
Date registered: Jan 2005
Paul
Paul,
why do you need heavy duty springs? Is it because you carry a full load, the van suffers from bodyroll when going round corners or both?
There are stiffeners (is that a word? LOL) that you can put in the spring coils that reduce the sag when loaded. I'll expect there's none available for the Vito, but it maybe worth looking at some caravan websites, because I know those people who tow those mobile roadblocks use them.
Ugly
ugly is offline   Reply With Quote
Old 07-04-2008, 12:06 PM   #5 (permalink)
Hello Ugly
Yes I run the van on it's full weight limit for long periods and just wanted a bit of "insurance" for want of a better word.If there was an uprated spring option then I would choose it but I am probably going over the top.
Cheers Paul
Old 07-04-2008, 02:40 PM   #6 (permalink)
tonto555's Avatar
Date registered: Apr 2008
Vehicle: 2000 Vito 108 cdi
Send a message via MSN to tonto555
Hello Ugly
Cheers Paul
I am aware of guys that have increased the weight carrying capacity of transit vans using leaf springs, not sure if this would suit you but if heavier load carrying is your aim you should also be careful re your braking system
tonto555 is offline   Reply With Quote
Old 07-05-2008, 10:26 AM   #7 (permalink)
Tonto
Not heavier load carrying but maximum permitted weight . The springs I have are standard but I had been told you can buy an uprated vito spring for these vans.
I'll check with the dealers.
Thanks Paul
Bilstein Heavy-duty shocks Benzoid123 W123 E,CE,D,CD,TD,TE Class 8 06-03-2007 08:51 PM
Heavy Duty Shocks? garrettsmith W123 E,CE,D,CD,TD,TE Class 4 12-22-2006 09:20 AM
Heavy Duty or Comfort Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 3 02-08-2005 09:26 AM
"Heavy Duty" SL600 MacDubois R129 SL Class 0 04-25-2004 12:13 AM
Heavy duty rear springs Tom Dee in San Jose W163 M-Class 4 07-20-2002 09:46 AM
