Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 06-24-2008, 06:14 AM   #1 (permalink)
Date registered: Jun 2008
vito glow plug & EDC light on???
Hi all,
i have a vito 110 cdi 52 reg (old shape) it has the glow plug light on all the time i have changed them all but its still on???? also the EDC light on to. it used to go like stink but since this EDC light came on it has no pull and wont rev past 3,000 revs
hope someone can help???
thanks
kev
kevin evans is offline   Reply With Quote
Old 06-24-2008, 07:17 AM   #2 (permalink)
energysolutions's Avatar
Vehicle: 2002 112CDI Vito
Originally Posted by kevin evans View Post
Hi all,
thanks
kev
If it wont rev past 3k then your are in "limp" mode - a safeguard built into the ECU to limit revs should a problem happen
Not sure whats caused it though...................
!!!!!Never eat yellow snow!!!!!
energysolutions is offline   Reply With Quote
Old 06-24-2008, 12:21 PM   #3 (permalink)
I changed my vito rad today and afterwards the glowplug light stayed on , found that the glow plug relay earth wire clamp had corroded away , not sure if this would cause edc to come on but might be one thing to eliminate .
charlzzz is offline   Reply With Quote
Old 06-24-2008, 03:08 PM   #4 (permalink)
thanks I'll have a look at all the earths.
one thing that i found today was the black box that sits on it's side on the left hand headlight panel has a red wire bolted to it that had corroded off!!! and the 4 pin block connecter had oil in it thought thats got to be it but nope lights are still on.
i did think it was in limp mode when i was overtaken by a citroen 2cv
i could do with getting it sorted asap as my girlfriend is moving on the 5 and i am racing at rockingham the weekend after
Old 07-17-2008, 03:11 PM   #5 (permalink)
Date registered: Jul 2008
Hi Kev,
I have a 2000 vito 108 CDI with EXACTLY the same problem. I've been stuck in limp mode for ages now and its driving me crazy....if anyone hears of a solution please help!! Took it to a Mercedes service centre and their laptop couldn't communicate with my ECU - all they told me was i had a rare model..... very helpful.
I've heard lots of different reasons for the EDC warning light to be triggered but none that seem to explain my problem. Any advice much appreciated
Dave
dy1502 is offline   Reply With Quote
Old 07-18-2008, 09:44 AM   #6 (permalink)
tonto555's Avatar
Date registered: Apr 2008
Vehicle: 2000 Vito 108 cdi
Send a message via MSN to tonto555
My advice, check the wiring and all the conneectors, make sure everything is connected securely. had a similar problem with a broken wire to my injector. Ive since changed all the wiring in the van, cost a fraction of what a so called merc mechanic qouted.
tonto555 is offline   Reply With Quote
Old 08-11-2008, 07:06 AM   #7 (permalink)
dannyboy16's Avatar
Date registered: Aug 2008
Vehicle: 2000 Vito 108CDI
Kevin let us know what you find? Ive just got the same problem.Cheers
dannyboy16 is offline   Reply With Quote
my vito engine cuts out, edc light on kab V-Class 16 01-26-2008 03:55 AM
Glow plug light... torkq W123 E,CE,D,CD,TD,TE Class 2 01-02-2008 10:33 AM
Glow Plug warning light & alarm go on every time I use blinker.... jtoma878 W123 E,CE,D,CD,TD,TE Class 1 01-02-2007 10:16 PM
glow plug light only comes on when 5 pin plug is disconnected from relay JLincoln W123 E,CE,D,CD,TD,TE Class 5 11-20-2005 04:58 PM
Glow plug light amolak V-Class 1 03-01-2005 01:12 AM
