Vito Pollen FIlter removal the easy way ? - Page 2 - Mercedes-Benz Forum
post #11 of 18 (permalink) Old 03-18-2009, 09:54 AM
Matelot's Avatar
Date registered: Mar 2007
Vehicle: 1999 108 Cdi Traveliner, 1999 V220 Cdi, 2003 V220 Cdi
Originally Posted by firebird.350 View Post
Thanks for that Rob, you wouldn't happen to know how to remove the "Glove box" bit would you!
Mark
I'm afraid not Mate, haven't found a need to yet.
Am tempted to have a go at the pollen filter though, as I didn't even know I had one.
Perhaps that'll improve the poor aircon/ventilation flow I've been putting up with for the past year.
I'll let you know if I get carried away & dismantle the glovebox too!
Cheers,
Rob
Matelot is offline
post #12 of 18 (permalink) Old 04-16-2009, 08:53 AM
Date registered: Jul 2003
Vehicle: 2003 112CDi Vito Van
My results: The filter didn't seem to result in less dust in the vehicle (112) and A/C not effective as could be.
Removal of filter has provided massive boost in A/C performance and airflow now very good on first fan setting.
Position of filter worst design (apart from Peugeot307) I've ever seen!!! Access pitiful, doesn't protect fan and ducting from dust.
Seems to create slight negative pressure in cabin, resulting in dust ingress.
T4 VW had filter in engine bay - 2min job to remove clean and restore.
Conclusion - designers never actually work on teir creations.
Regards
Rob K
RHKVito is offline
post #13 of 18 (permalink) Old 04-16-2009, 12:13 PM
Bright spark's Avatar
Date registered: Jun 2008
Vehicle: Vito 115cdi 2005
The 639's pollen filter is also in the engine bay - takes 2 screws to remove.
Bright spark is offline
post #14 of 18 (permalink) Old 04-17-2009, 02:50 PM
tonto555's Avatar
Date registered: Apr 2008
Vehicle: 2000 Vito 108 cdi
Send a message via MSN to tonto555
Mark
This is quite easy. Youll need to lie on the floor, remove the kick panel so you can get acces under the dashboard, there are 3 plastic "pegs" on either side of the glove box section, I advise the use of a small headlamp so you can see what your doing.
These pegs are melted or glued into the holes and you will hve to either break or melt them out. I used a soldering iron to get mine out.
Then there are 4 or 5 flat "tabs" along the bottom on the inside, again glued or melted, same technique required.
Epoxy resin on all tabs and pegs to replace, line up the tabs on the bottom, pegs should just slide into place, tape up and leave to set.
You can only remove the section thats painted in the photo, the actual glove box holes are part of the dashboard itself.
tonto555 is offline
post #15 of 18 (permalink) Old 08-02-2013, 01:23 AM
glyndwr's Avatar
Date registered: Aug 2013
Vehicle: v230
is their a diagram on how to remove pollen filter ,,, would by very helpfull ... cheers martin
glyndwr is offline
post #16 of 18 (permalink) Old 08-02-2013, 01:42 PM
Matt910's Avatar
Date registered: Jan 2013
Vehicle: Vito 112 CDI 2002
Matt910 is offline
post #17 of 18 (permalink) Old 08-02-2013, 01:44 PM
Matt910's Avatar
Matt910 is offline
post #18 of 18 (permalink) Old 08-04-2013, 10:48 PM
glyndwr's Avatar
Vehicle: v230
thank you very much ,,, love this site
glyndwr is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
    pollen filter stevedunphy V-Class 10 11-07-2012 04:42 PM
    Pollen Filter gordon scott W210 E-Class 4 12-23-2006 08:47 PM
    replacing clutch bar after pollen filter removal kaiser V-Class 2 09-26-2006 02:35 AM
    Pollen Filter $? Kiawah W140 S-Class 4 04-27-2006 06:24 AM
    Pollen Filter & Petrol Filter englishmathew V-Class 3 08-22-2005 05:57 AM
