» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 01-13-2008, 02:20 PM   #31 (permalink)
stoneboy's Avatar
Date registered: Jun 2007
Vehicle: V280 LPG 2000
Don't mind at all. Only reason I've not posted anything about them before is that I know nothing about them. I don't know the offset or their width. I do know that they are not made any more.
If the previous owner (hi ) reads this he might be able to tell you more.
stoneboy is offline   Reply With Quote
Old 01-13-2008, 02:26 PM   #32 (permalink)
stoneboy's Avatar
Actually, what I can say is the with 245 tyres the rear archs needed rolling and the fronts rub on full lock. I've just replaced two tyres that had a fair amount of tred on them when I found that the inner edges were down to the wire! I'm hoping that if I don't turn the wheel to full lock then the replacements will be OK. Can't see how they could be rubbing anything other than when on full lock anyway.
Old 01-13-2008, 02:36 PM   #33 (permalink)
HotPanties's Avatar
Date registered: Dec 2007
Vehicle: Previous Project = E30 Alpina --- 8 years later, Project V230
wow, if it's that bad, turn the steering full lock and have a nose around inside around the back of the wheel. You should see the remains of molten rubber stuck to the inside walls along with a distint impression of where teh wheel has been rubbing.
I think you'll be better off with 235's on the front. I remember reading somewhere (can't find the thread now ) that 235's were best suited for fronts over 245's. But I guess that's too late now that you've already replaced them.
HotPanties is offline   Reply With Quote
Old 01-13-2008, 02:39 PM   #34 (permalink)
HotPanties's Avatar
oh, you mentioned that rears needed rolling. Is that with the standard air suspension? And was that because a lot of weight was being carried in the back? please say yes to the second question, cos otherwise i'm screwed
Old 01-14-2008, 02:41 AM   #35 (permalink)
gixxerpat's Avatar
Date registered: Sep 2005
Vehicle: vito108cdi ,zx7r,gsxr 750, ford consul rod, ford pop rod, Custom Astrovan,New toy.. Benelli Tornado.
I'd get the tracking checked asap mate, just rubbing on full lock wont wear the tyres that unevenly, i had the same problem with the outside of mine...sounds like its squatting, wider wheels always need to be re-tracked..
Praise the Lowered..
gixxerpat is offline   Reply With Quote
Old 01-14-2008, 02:59 AM   #36 (permalink)
stoneboy's Avatar
Don't think the suspension being air makes any difference. With that width of tyre and that wheel offset they need doing.
The previous owner did them and as far as I am aware it was a problem without any weight being carried. Certainly it looks like it would have been a problem anyway.
Old 01-14-2008, 03:00 AM   #37 (permalink)
stoneboy's Avatar
The tracking and everything had been re-done since the new wheels were fitted. Perhaps I should get them re-done.
I can however hear it rubbing on full lock, can't see any bits of rubber anywhere though. I'll have a look with it on full lock to see where it's happening to make sure it's that that is doing it. Not bothered before as with the rubbing noise I assumed it must be that.
If they are definitely rubbing on full lock and it's exactly where the rubber loss was would you still recommend getting the tracking done?
Old 01-14-2008, 04:37 AM   #38 (permalink)
HotPanties's Avatar
i have no idea how air suspension is in comparison to standard setup so good to hear it has no affect.
I'm curious to know what the offset is on your alloys. I've just got a set which are 9" wide all round with 275/40's load rated at 105 wrapped around them with an offset of 41. Going to have to change the fronts to something around 235-245 so will have to wait and see how it pans out.
Rears are running 275 michelins with about 7mm grip left on them so wanted to keep those on there for now. More importantly they look sweet!
Question is, how the hell do i get them to sit on the back without catching doors and shredding the tyres?
Old 01-14-2008, 09:10 AM   #39 (permalink)
gixxerpat's Avatar
Stoneboy..where are they worn , inside corner, including the sidewall or just the thread part...are they unevenly worn across the whole width...another thing to consider is if the tyres are not XL or RF they will wear badly on the shoulders...leaving loads of thread in the centers....pix might help..
BTW..what width are your alloys..?
Old 01-14-2008, 09:25 AM   #40 (permalink)
HotPanties's Avatar
never thought about that. better fix the order of my front tyres!
Oh well, ya learn something every day
HELP! I Need OEM Alloy Lugs/Bolts for 18" or 19" Alloy Wheels smarten W164 M-Class 1 08-05-2007 01:17 PM
I Choose These Wheels Mr.benza V-Class 5 04-06-2007 04:21 AM
How to choose the right wheels. Benzlova W163 M-Class 10 12-26-2006 07:10 PM
Help me Choose wheels for 300ce top222 The Discount Tire Direct Tire, Wheel, Brake & Suspension 7 08-14-2006 11:28 AM
Wheels to Choose from this 3 options (ML) Celso W163 M-Class 15 10-07-2005 12:34 AM
