» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 04-12-2007, 02:55 PM   #1 (permalink)
nail it's Avatar
Date registered: Jan 2007
Vehicle: 108d big orange shaggin wagon got a v280
Central Locking
right its not been right from the day i got it
any door same thing happens
turn key to lock and let go it locks unlocks
do it again it locks unlocks then locks
any ideas ?
i think its the contol box under the dash thats the problem
if so any one got one
nail it is offline   Reply With Quote
Old 04-12-2007, 03:57 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: Vito 112 CDi year:2001
Is it Mercedes original, or after market. Had a similar 'locks bouncing open' problem with my aftermarket central locking.The wiring had gone where it runs through the rubber boot by the door hinges . I replaced both sides rather than work out which had gone. I needed 5 core cable, but could not get hold of any, so used 7 core trailer wire.
Other thing that make the locks bounce are dirt/corrosion on the sliding door contacts and the servos being positioned too close or far from the lock. You only have to move them a few millimetres for them to start bouncing. You'll obviously have to remove the door trims, disconnect the arm between the servo and the lock and then push & pull on the servo hook. If the bouncing stops then thats the servo thats positioned wrongly.
4xpaws is offline   Reply With Quote
Old 04-12-2007, 04:18 PM   #3 (permalink)
nail it's Avatar
its the original systerm 4xpaws ill av a play see wot give lol
Old 04-13-2007, 01:02 AM   #4 (permalink)
No experience of merc's CL. But I when I was looking for info on my CL problem the wires failing in the rubber door boots cropped up for merc CL too.
Old 04-13-2007, 04:30 AM   #5 (permalink)
Sarge786's Avatar
Date registered: Apr 2005
Vehicle: V220 CDI 2003
Send a message via MSN to Sarge786
any ideas ?
Nail it, there is a problem that occurs due to broken wiring through the boot between the doors as 4xpaws says, this happens on Mercs fitted system, and one of our forum friends recently discovered that the PASSENGER door boot had broken wires in it, strange he says as that door doesn't get used much?!
Clean the slider contacts first to eliminate these.
If you open a door ...say the drivers door, get a screw driver and use it to 'manually' lock the lock in the door shut potition, then try to lock it, to release the mechanism, simply use the door handle and it will click back in 'open' position.
Do this to each door and see what happens.
MERCDADS = Mercedes Dealers Are Donkeys
Sarge786 is offline   Reply With Quote
Old 04-15-2007, 03:06 PM   #6 (permalink)
nail it's Avatar
looks like it the control box so need new one
unpluged every door in turn same thing happens
central locking but different volitain V-Class 2 12-18-2006 12:31 PM
Central Locking rmassa Audio & Telematics Forum 1 12-08-2006 11:48 AM
Central Locking MLFC W163 M-Class 1 06-15-2006 03:17 PM
central locking black benz W201 190E, D-Class 6 07-31-2005 02:05 PM
central locking stevie V-Class 2 06-06-2005 12:47 AM
