» Site Navigation » Other Sites
» Network Links
01-03-2007, 08:35 PM
#1 (permalink )
Date registered: Jan 2007
108 cdi temp fan / temp gauge problems
Hi I'm hoping someone has an answer to by problem. My 108cdi Vito has aproblem with the coooing fan / temp gauge, when the cooling fan for the radiator comes on it sends the temp gauge up instantly as if there is a electrical short. whan the fan switches off the temp gauge coes back to normal, it also so effects the engine like a stutter. Also so I check to see if the engine has overheated but you could easliy remove the radiator cap without getting burnt by hot water.
01-04-2007, 02:58 AM
#2 (permalink )
Date registered: Oct 2004
I would suggest that you check the resistance of the coolant temp sensor or just replace it if you don't have time
Just a thought ?
01-21-2007, 12:09 PM
#3 (permalink )
How do you replace coolant temp sensor?
I am having the same problem. How do you replace the coolant temp sensor?
05-04-2007, 11:11 PM
#4 (permalink )
Hi i've justpurchased one , but was unable to locate the position on the engine, rgds
Chris
05-21-2007, 04:18 AM
#5 (permalink )
Just replaced the sensor, I wish I had smaller hands though...! all electrics
workinh fine.
many thanks for your help...
07-01-2007, 05:16 AM
#6 (permalink )
Date registered: Jul 2007
workinh fine.
Could you send me info on how to replace sensor, having similar problems#
sharon.stevens3@tesco.net
Thanks
Thread Tools Display Modes Linear Mode
Similar Threads Topic Author Forum Replies Last Post Temp gauge Mouramen W124 E,CE,D,TD Class 8 06-14-2006 09:10 PM Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 10:03 AM temp gauge please help? gravel W163 M-Class 4 04-18-2005 09:46 AM 300E Running at High Temp Fan Clucth and Heater Core Problems Khizer W124 E,CE,D,TD Class 9 09-25-2003 08:58 AM When outside temp is higher than 40', how come the temp gauge still shows 40'? noelb W163 M-Class 5 04-16-2002 02:43 PM
