» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 12-12-2006, 12:43 PM   #1 (permalink)
Date registered: Dec 2006
alloy wheels
are there any other wheels that would fit on my vito other than merc ones
welsh wizzard is offline   Reply With Quote
Old 12-12-2006, 04:47 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: V230 Auto
Mate, there's loads.
Get a copy of a boy racer mag and have a llok in the back, there are hundres of alloy places and most will do wheels for the vclass/vito
Also, try halfords, they have some brilliant deals on at the mo.......
and
check out the thread headed pimping by sarge, has loads of pics to give you some ideas
Steve
Smifster is offline   Reply With Quote
Old 12-12-2006, 07:45 PM   #3 (permalink)
Date registered: Oct 2006
On the alloy front, from my experience with a 115, be sure to check the maximum loaded weight of your van against the carrying capacity of the wheels - for instance C class wheels will fit PCD wise BUT have been known to crack when fitted to 115's obver here, the C class is much lighter than a loaded Vito.
The next issue to check is bolt diameter, I had some issues with the first few sets I ordered came with M12 bolt holes instead of M14, then finally, the inner spigit diameter on the aftermarket (non MB) wheels is larger than the McCoy benz wheels, this is easily fixed by adding spigot rings - after 30 000km's the plastic spigot rings on my front wheels pushed into the inside of the wheel so the next charlie who removed and refitted the wheels did not notice that it needed spigot rings and just refitted them - OFF CENTRE!!. Leads to some hectic vibes from the steering wheel and pretty f@cked up tyre wear...the moral of teh story......proceed yes, but with due care.
Post pics when u is finished yes?
rufus is offline   Reply With Quote
Old 12-13-2006, 01:26 AM   #4 (permalink)
Benz Bling's Avatar
Date registered: Sep 2004
Vehicle: Vito 113
alloy wheels
Hi Welsh Wizard,
For alloys try the following companies: -
Team Dynamics www.rimstock.co.uk
O.Z www.ozracing.com
Mille Miglia www.millemiglia.co.uk
AEZ www.wheelwright.co.uk
If I were you I'd keep away from any 'replica' wheels because of weight issues etc. I have a set of 17" O.Z's on mine and I have not had any problems at all. Forgive me for being presumptuous but if you do live in Wales I would contact Demon Tweeks, I bought my wheels there and found them to be very knowledgeable and extremely helpful.
Hope this helps.
Benz Bling
Benz Bling is offline   Reply With Quote
Old 12-13-2006, 02:28 PM   #5 (permalink)
adamuk's Avatar
Date registered: Apr 2006
Vehicle: Vito 108 CDi 1999 + 112CDi on its way.
Yeah dude, post pictures!
My van's windows are getting the limo tint treatment tomorrow. Once the alloys are on I will get mine posted too.
adamuk is offline   Reply With Quote
Old 12-14-2006, 04:29 AM   #6 (permalink)
darkside's Avatar
Date registered: Sep 2006
Vehicle: Vito 110 CDi
Limo tints look the bomb, dude - you'll be chuffed for sure.
As for alloys, Benz Bling is on the money - don't get cheap ones unless you like your rim parting company from the spokes. It does happen and I doubt it's fun.
I went for OZ Racing as they can give a guaranteed axle load figure. Check out your curb and gross vehicle weights and decide what load you are going to carry and if you are comfortable with the alloys you are looking at.
But don't get too paranoid - the figures I found show that a Vito is only 300kg heavier than an A class! Imagine an A class with 5 big guys in and the gap closes a lot....
It's when you put 1000kg in the back of the Vito you need to worry (or 8 passengers in a V class) about your wheel strength. If you only carry a couple of hundred kilo then any quality branded, preferably forged instead of cast, rim should do the trick.
I'm on 17" by 7.5 with 225/55/17 tyres. Also check the tyre load rating.
darkside is offline   Reply With Quote
Question on Alloy Wheels Winston W123 E,CE,D,CD,TD,TE Class 1 06-20-2006 07:12 PM
Looking for G Alloy Wheels mferguson G-Class 4 12-15-2005 07:01 AM
Which 16" alloy wheels ...... Punjabi V-Class 1 03-17-2005 12:06 PM
15" Mercedes Alloy Wheels Ridd G-Class 0 11-09-2004 02:51 PM
Alloy wheels Guest (MBNZ) W211 E-Class 4 02-04-2002 12:08 AM
