» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 11-19-2006, 03:45 AM   #1 (permalink)
Date registered: Nov 2006
how can i remove the armrest?
my car is v280.
i want to install three rear seats in centre row,
how can i remove the armrests?
can you teach me step by step?
thank you so much.
mw888 is offline   Reply With Quote
Old 11-19-2006, 04:11 AM   #2 (permalink)
Sarge786's Avatar
Date registered: Apr 2005
Vehicle: V220 CDI 2003
Send a message via MSN to Sarge786
Here you go matey, see attachment.
Installing and removing the armrests
Swing the armrests up.
Press the
swivel hinge of the armrest against the backrest and as you do so
pivot the armrest back by about 45°. The armrest can be removed in this
position. Cover the armrest socket with the appropriate caps.
To install, place the armrest into the socket in the 45° position - the unit may
otherwise be damaged. Press the swivel hinge gently against the backrest
and pivot the armrest forwards.
Note:
Do not use force when fitting or removing the armrests.
Regards
SARGE
MERCDADS = Mercedes Dealers Are Donkeys
Sarge786 is offline   Reply With Quote
Old 11-19-2006, 04:33 AM   #3 (permalink)
lilstar's Avatar
Date registered: Oct 2006
Vehicle: 1998 A 160 1998 V230 TD 2008 Vito 115 Extra Long
Originally Posted by Sarge786
Here you go matey, see attachment, this is the origianl instructions out of the manual.
Regards
SARGE
hey sarge can you also send me the copy of the manual
thanks
lil
lilstar is offline   Reply With Quote
Old 11-19-2006, 04:50 AM   #4 (permalink)
Sarge786's Avatar
Hi, I am unable do that as I only have my original one, I scanned that page and uploaded it with a lot of difficulty, due to the forums attachments limits.
Somehow, I will try to do this for everybody at some stage.
Regards
SARGE
Old 11-19-2006, 05:58 AM   #5 (permalink)
thank you very very very very very .......................... much!
Press the
Note:
Regards
SARGE
Old 11-19-2006, 06:03 AM   #6 (permalink)
lilstar's Avatar
hey sarge how about the driver seat how can i remove the armrest i have to change the gear on it ...thanks
Old 11-19-2006, 06:28 AM   #7 (permalink)
Sarge786's Avatar
Hi, I believe its the same method as above.
Regards
SARGE
Old 11-19-2006, 07:34 AM   #8 (permalink)
hi Sarge, i cannot back the armrest by 45°.(see attachment)
can u help me again?
Old 11-19-2006, 08:44 AM   #9 (permalink)
Sarge786's Avatar
Once up, I think you have to 'push' the armrest against the seat, and hold it there, while moving it backwards, which then allows it to move back to the 45 degree angle.
Old 11-19-2006, 07:13 PM   #10 (permalink)
i can remove the armrest.
thanks for your help.
thank you very very very very very very very ........much!
Remove front center armrest ranger 65 R/C107 SL/SLC Class 7 10-01-2007 07:20 PM
Remove armrest on 280 SE 1984 snyggsomfan W126 S,SE,SEC,SEL,SD,SDL Class 9 05-24-2006 08:24 PM
How to remove front armrest? flyboyike W123 E,CE,D,CD,TD,TE Class 1 01-24-2005 10:56 PM
How to remove front armrest? flyboyike W123 E,CE,D,CD,TD,TE Class 0 01-24-2005 09:15 PM
How to remove folding armrest? (1990 300E) alanmb W124 E,CE,D,TD Class 1 12-23-2004 07:24 PM
