vito injector removal help!! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-08-2006, 05:57 PM Thread Starter
hi. can anyone give me any tips on removeing and reseating my injectors on my vito 110cdi (v). i have removed the hard black carbon build-up and there is smoke comeing from No.2 injector. so any advice would be helpfull!
thanks pete
tibbenham is offline
post #2 of 6 (permalink) Old 11-09-2006, 06:31 AM
Date registered: Sep 2006
Vehicle: 1994 W124 E300d & 1994 S124 E300d
If you put Mr.Muscle oven cleaner around the seat of the injectors when the engine is hot and leave it for 10mins. i believe this can release the sticking injector.Just don't try and force it,if it means taking the head off to get a better purchase on the injector then do it.
Swannymere is offline
post #3 of 6 (permalink) Old 11-10-2006, 10:28 AM
montymole's Avatar
Date registered: Feb 2005
Vehicle: V 220 CDI Trend
Red face
See the comments on the post
http://www.benzworld.org/forums/v-cl...low-plugs.html
and good luck, it can be a B*std job.
montymole is offline
post #4 of 6 (permalink) Old 11-11-2006, 05:08 AM Thread Starter
thanks for that! so i will NOT use oven cleaner and the best tip is to run upto temp and i'm going to use duck oil around the injector before i start to remove.
with all the black carbon now off i can see it's only No.2 injector leaking so i will only do that one.
post #5 of 6 (permalink) Old 12-13-2012, 05:45 AM
Date registered: Dec 2006
If you require the tool for removing the injectors in the UK here will rent a special puller at a reasonable price. It certainly helps to do it on a hot engine as it's expands the alloy head a bit.
quarryman is offline
post #6 of 6 (permalink) Old 12-13-2012, 09:43 AM
lottylotus's Avatar
Date registered: Dec 2012
Vehicle: vito 108 cdi/slk compressor/esprit 88 turbo/1.2 corsa/CBR 1000 IN BITS
i will be doing mine over crimbo,,rang diesel bob at ribchester(lancs) and he wants 70 quid per injector to refurbish ,,he will test them for abot 8 quid each ,,pretty quick turn around ,,he did our corsa van last month,,those injectors where a piece of p##s to change about 15 mins(bet the vito take me longer)
i just need those lottery numbers(thats all)
lottylotus is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
    Vito door trim removal ALonDonThinG V-Class 7 12-01-2011 05:40 AM
    cab removal/ head removal/ hydraulic install/ esde Unimog 25 03-28-2010 05:33 PM
    It must be the injector? Skogs W123 E,CE,D,CD,TD,TE Class 11 11-19-2006 07:19 PM
    220 CDI diesel injector removal montymole V-Class 1 01-15-2006 04:33 PM
    Prechamber / injector removal / leakfix a1jatt W201 190-Class 0 04-14-2005 10:17 AM
