» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 09-14-2006, 03:34 PM   #1 (permalink)
Vehicle: 111 cdi vito compact. and C 270 cdi SLK320
Over heating
Hi, The v280 is over heating in traffic, I think it is the fan.
Any idea how to get it out, its very tight down there.
Ian UK
zenman 63 is offline   Reply With Quote
Old 09-15-2006, 04:08 PM   #2 (permalink)
Date registered: Aug 2006
Vehicle: V230 Auto
Hi Ian,
I've got a V230 auto and when i sit in traffic the needle on the temp gauge used to go up to 110 befor the fan would kick in. As a result i spent over £500 trying to solve the problem only to be told that the V Class series often run hot, and it's quite common for the fan to only kick in when the needle is nearly touching the red............
Is your V280 hitting the red?
Smifster is offline   Reply With Quote
Old 09-16-2006, 04:24 AM   #3 (permalink)
Yes, just in the red, then pumps the water out!
It has not done it again, but i have found the fan is working, it starts slowly and speeds up.
It is about 90 deg normal.
Cannot see why it overheated.
What it did do the next day was, a spark plug came loose! must have been expantion.
Ian
heating BK.....Beamer Killer W126 S,SE,SEC,SEL,SD,SDL Class 0 01-16-2005 04:33 PM
Heating Terabyte W126 S,SE,SEC,SEL,SD,SDL Class 3 10-25-2004 09:17 AM
Over Heating?? Bklyn1971 W163 M-Class 4 09-25-2004 05:20 AM
Heating - my car still heating Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 07-02-2002 09:22 PM
over heating Guest (MBNZ) W201 190E, D-Class 5 08-20-2001 07:58 PM
