Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 08-30-2006, 10:31 AM   #1 (permalink)
Date registered: Jul 2005
V220 - Transmission Noise
Hello, I wonder if anyone had a similar problem and may be of help:
I own a V220, 2001 model with 150k Kms. The Van has Automatic Transmission.
I hear a rather strong clok noise when the driveshaft is first loaded or when it is unloaded. For example when I put it into Drive or Reverse (or change between one and the other), or when, while driving, a drop the accelerator pedal and push on it again. It is as if there was some slack in the transmission somewhere.
Any clue or advise would be GREATLY appreciated
regards to all
Pietro
barabap is offline   Reply With Quote
Old 08-30-2006, 03:01 PM   #2 (permalink)
Punjabi's Avatar
Vehicle: Bandwidth
The 'clunk' is normally the result of a broken accumulator spring in the valve body, common problem with the ZF trannies. It is a fairly easy job to replace for the keen DIY but do not try it if you are not a hand with car mechanics. Spares for the ZF trannies can be obtained from Sussex Autos who are approved ZF dealers and autobox specialists.
Although the V Class (V230) has a ZF HP20 gearbox, my SAAB has a ZF HP18 gearbox which had this problem - after replacing this spring in the valvebody, it was real smooth once again!
Punjabi is offline   Reply With Quote
Old 08-31-2006, 01:45 AM   #3 (permalink)
Thanks, I have some experience in car DIY (rebuilt a couple of engines etc) and have access to a workshop where I can do some repair work myself but not really in any transmission work. Do you have any link which I can use to understand what needs to be done and where is the part to replace?
Many thanks
Transmission noise alweaver W210 E-Class 6 10-12-2007 05:18 AM
transmission noise stewedg R129 SL Class 4 02-28-2007 01:47 PM
"Clunking" noise from transmission wmedia W140 S-Class 0 08-16-2005 02:13 AM
Vibration noise when transmission shifts bumanng R170 SLK Class 1 01-09-2005 09:00 PM
screeching noise from transmission when using heat dieseldude W123 E,CE,D,CD,TD,TE Class 4 02-25-2004 07:50 PM
