Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 08-24-2006, 06:17 AM   #1 (permalink)
Date registered: Aug 2006
Vehicle: Vito 113, X-Trail
Immobilizer System Fault?
Hi, I am new to this forum and really love my 2000 Vito to death.
But I could really use the help of anyone who has a similar problem to mine and managed to solve it.
My Vito 113 cranks over a second or two when I start it. Then dies. Each time I start it, it'll crank over the same span of time, then die completely.
I think it's the immobilizer system and have located it behind the instrument cluster, but I have no way of detecting if it's the faulty party. I've tried both my keys - same effect.
1) Does an immobilizer fault show up on an OBD II reader
2) What is the code?
3) Has anyone replaced his unit and how much does it cost?
4) Do the keys need to be reprogrammed?
I'd bring it to the dealership - but the local one here is a complete ripoff!
So Im trying to fix this with the help of some of the experts here.
Thanks in advance!
leongster is offline   Reply With Quote
Old 08-25-2006, 08:46 AM   #2 (permalink)
Uhh, I finally got my immobilizer to work. Seems it was a contact problem with the wires on the unit. After a bit of jiggling it works fine now.
Old 08-27-2006, 10:46 AM   #3 (permalink)
adamuk's Avatar
Date registered: Apr 2006
Vehicle: Vito 108 CDi 1999 + 112CDi on its way.
Welcome! There's not much expertise here (or if there is, it comes out very slowly..) The MB workshop manual is available on ebay (comes as 3 or 5 DVDs) and it's definitely helped me out of a few tight spots.
Cheers
Adam.
adamuk is offline   Reply With Quote
Old 08-28-2006, 02:15 AM   #4 (permalink)
Cheers
Adam.
Thanks for the lead. I got the manual by Russek, and it is a little basic. Will get the CDs.
Best,
Eddie
bought 1999 S reg s/a a class cant find immobilizer port 2 put my immobilizer key in Ali_c W168 A-Class 2 08-28-2005 01:01 PM
Immobilizer spit64 W124 E,CE,D,TD Class 1 07-30-2005 12:04 PM
Immobilizer Cmdr737 R129 SL Class 3 04-11-2005 11:53 AM
Clearing fault codes from the system ally_230ce W124 E,CE,D,TD Class 2 01-24-2005 02:28 PM
ML Tech Trivia: Immobilizer S4toML W163 M-Class 8 12-18-2002 02:47 PM
