Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 08-09-2006, 02:32 PM   #1 (permalink)
Date registered: Aug 2006
Vehicle: Vito 112 CDi year:2001
vito jacking points
Just got a 112 and need to jack up the front.
Whereabouts can you place a trolley jack to jack up the front wheels at the same time? Finally where should you place the axle stands to support it?
4xpaws is online now   Reply With Quote
Old 02-13-2007, 01:01 PM   #2 (permalink)
Here's the jacking points I'm using to raise my vito with a trolley jack
Raising both front wheels: I put the jack central on the bar and then place 2 axles stand spaced apart on the same bar
Raising one front wheel: I put the jack with a block of wood on top of the lifting plate and place here:
Raising one rear wheel: jack here again using a block of wood as a buffer between jack and box beam.
I've yet to work out how to jack up both rear wheels together and place on axle stands. I would want to place the stands on the box beam where I'm currently jacking up the rear wheel.
Any ideas anyone?
Old 02-17-2007, 12:34 PM   #3 (permalink)
DBTRANSPORT's Avatar
Date registered: Dec 2006
Vehicle: 316cdi
Id place your jack under the swing arm about in line with the coil spring in your pic, place the axle stand under the "box beam". Lower the jack and repeat on the other side.
DBTRANSPORT is offline   Reply With Quote
Old 02-18-2007, 04:25 AM   #4 (permalink)
zx9
zx9's Avatar
Date registered: Oct 2006
Vehicle: 2000 108CDi, 99 A4 1.8T, 98 ZX9R, 84 GPz1100, 76 Range Rover 2dr.
Good pics 4xpaws, may be time to sort out some of the surface corrosion before it gets too much of a hold. Also check out the insides of front inner wing box sections, remove the indicators and you can see insided the box structure. Remove loose paint and rust, apply rust converter, a good primer and spray in or paint on wax. Take a bit of time now it will save more time and expence in the long run.
Regards
ZX9
zx9 is offline   Reply With Quote
Jacking Points for CL500, help..... JKRD101 W215 CL Class 1 10-02-2004 10:34 AM
ML Undercarriage Jacking Points N1ML W163 M-Class 8 03-07-2004 04:39 AM
Trolley jacking points? Vincent W126 S,SE,SEC,SEL,SD,SDL Class 2 01-05-2004 04:46 AM
Jacking up the ML... dewdaltz W163 M-Class 9 05-07-2003 04:56 PM
HI lift jacking points on a G wagon Irish sean G-Class 2 07-29-2002 11:17 PM
