| RE: Pollen filter change........ Try this site, its in Japanese but the pictures should help
http://translate.google.com/translate?hl=en&sl=ja&u=http://www.v-style.jp/&prev=/search%3Fq%3Dhttp://www.v-style.jp/%26hl%3Den%26lr%3D%26client%3Dsafari%26rls%3Den & click on Method, the pictures are on the right side, first set, right bottom pics
If it dosn't help try this, after the lower console is removed there is cylindrical rod behind it with a 13 mil bolt on either end, remove this & behind this is plastic strip approx 18in + 1 in with a tab on it. Slid this to one side, the filter is behind this, it needs to be hooked out with a screwdriver, I didn't put a new one in as it was to difficult.The heater is about 300% better.
Another thing I did was block off the vents just behind the drivers seat so all the heat goes to the vent in the rear, that made another big difference.
Alan |
