Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 03-21-2006, 11:56 AM   #1 (permalink)
Date registered: Nov 2005
AUTOMATIC GEARBOX FLUID
Can anyone tell me hoe much automatic transmission fluid needed too refill a empty automatic gearbox (V230) too also include the torque converter.
Also is it necessary too fill it with mercedes genuine part, or will dextron 3 do the same job but cost a lot cheaper?
dextron 3 £15 = 5 litres
mercedes £48 = 5 litres
thanks for any replies
tommy
TOMMYMCA79 is offline   Reply With Quote
Old 03-23-2006, 07:21 AM   #2 (permalink)
Punjabi's Avatar
Vehicle: Bandwidth
RE: AUTOMATIC GEARBOX FLUID
Hold your horses! The V230 auto box is a sealed unit which is factory filled with SYNTHETIC GEARBOX OIL. It does not have a 'dip-stick' to check levels. The gearbox is a ZF unit which is also used in Renaults, Alfa, etc. However, the idea is to prevent people unnecessarily tinkering with the gearbox (using wrong oils, etc). It is not recommended to change oil unless you have had the box reconditioned, etc. However, if you have got to the stage of an oil change/refill, check with Merc for the original synthetic oil spec and use that...NOT ANY OTHER![:o)]
MERC DO NOT MAKE OIL, SO YOU CAN BUY SAME SPEC FROM ELSEWHERE MUCH CHEAPER, BUT MAKE SURE IT IS SAME SPEC!
Punjabi is offline   Reply With Quote
Old 03-30-2006, 12:01 AM   #3 (permalink)
Vehicle: 1993 300 SL 24V
Auto box on mine [vito 114 2.3] is definitely not sealed..
you have 2 plugs,1 for draining and 1 for refill.
first you drain from the bottom and then you refill from the side till the fluid pops out and then you screw it back on.
Unfortunately the filter is inside and cannot be changed unless you take the gearbox apart...
My Vito manual states: auto box oil change at
90000 kms....[55000 miles]
So you have to change it.....
dafi129 is offline   Reply With Quote
Old 07-29-2006, 08:25 AM   #4 (permalink)
Automatic Gearbox Fluid
Originally Posted by Punjabi
Hold your horses! The V230 auto box is a sealed unit which is factory filled with SYNTHETIC GEARBOX OIL. It does not have a 'dip-stick' to check levels. The gearbox is a ZF unit which is also used in Renaults, Alfa, etc. However, the idea is to prevent people unnecessarily tinkering with the gearbox (using wrong oils, etc). It is not recommended to change oil unless you have had the box reconditioned, etc. However, if you have got to the stage of an oil change/refill, check with Merc for the original synthetic oil spec and use that...NOT ANY OTHER![)]
I am still strugleing to find information for substitute of Mercedes ATF for my V230. I bought 5 l bottle COMMA AQM (it says meets DEXRON IID) but don't know whether is the right one. Can you help?
Thanks
anmar is offline   Reply With Quote
Old 08-04-2006, 04:00 PM   #5 (permalink)
in tjhe end had full gearbox overhaul, not sure on oil they used
people on this forum have recomended merc oil ONLY
Old 08-24-2006, 06:39 AM   #6 (permalink)
Date registered: Aug 2006
Vehicle: Vito 113, X-Trail
tommy
Tommy,
I am not certain about the 230 autogearbox, but my manual 113 uses ATF+4.
You can also use Mopar ATF+4
(Chrysler uses it in their Getrag gearbox.)
It's important to use the right fluid. I tried Dexron III for a short while but ended up refilling with ATF +4.
leongster is offline   Reply With Quote
Old 08-24-2006, 02:01 PM   #7 (permalink)
Date registered: Aug 2005
Check your gearbox for model number. It should be ZF 4HP20 see attached link. Do not use any other spec oil or you will be sure to have problems.
http://www.autoshoppingcenter.com/tr...foilguide.html
carpy is offline   Reply With Quote
