Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > V-Class
Old 01-30-2006, 10:27 AM   #1 (permalink)
Date registered: Jan 2006
Rear brake compensator vavle
Hi there i have just fitted new discs and pads to the front of a vito 108 and while doing that I adjusted the handbrake so that is all good . But when braking the brakes dont seem to be as good as they should be . There dont seem to be much braking fron the rear brakes .So the questin is how does this valve assembly work and can it be overriden so that there is a good bit of braking from the rear ?
Thanks
THE VIKING is offline   Reply With Quote
Old 01-30-2006, 12:33 PM   #2 (permalink)
gixxerpat's Avatar
Date registered: Sep 2005
Vehicle: vito108cdi ,zx7r,gsxr 750, ford consul rod, ford pop rod, Custom Astrovan,New toy.. Benelli Tornado.
RE: Rear brake compensator vavle
Did u bleed the system properly, as the system is split diagonally i.e. front right rear left and vise versa,this happened me when i took my calipers off to paint.[:0]
gixxerpat is offline   Reply With Quote
Old 01-30-2006, 02:13 PM   #3 (permalink)
I have not removed the calipers atall just fitted new front discs & pads but feel that the brakes are well below par . As for the diagonal arangment whats the method on bleding the whole system ?
CHEERS
Old 01-30-2006, 10:11 PM   #4 (permalink)
Date registered: Aug 2005
Did you use genuine MB parts. I have found with both VW and Mercs that none original brake pads in particular have never been as good as originals,worst for me were EBC pads on Vito.In Australia MB parts are cheaper than after market,thus false economics to buy non original.However VW parts are upto 3 times the price of after market replacement parts.
You may get some improvement after they bed in (400 klm)
carpy is offline   Reply With Quote
Old 02-03-2006, 10:54 AM   #5 (permalink)
carpy - 1/31/2006 12:11 AM
They where Brembo discs and jurid pads they seem to be getting better But I am going to change the rear as well
Cheers
