MD, Anne Arundel County - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-19-2014, 08:30 PM Thread Starter
Forum Administrator RC Colas® & Moon Pies®
Digmenow's Avatar
Date registered: Oct 2006
Vehicle: 1981 380SL 151K: 2001 E320 4Matic Estate 147K: 2008 E350 Sport 4Matic 120K: 2005 S500 116K
Quoted: 1128 Post(s)
I use these folks exclusively.
Autohaus Incorporated
215 Najoles Rd
Millersville, MD 21108
(410) 987-0130
Ask for Claude. He will give it to you straight.
Here's a breakdown of work he performed for me last year when I opened the hood on my 107 and saw this...
Timing Chain Problem
R&R Air Cleaner, Plug Wires, Valve Covers, Power Steering Pump
Sprocket, Cruise Control Unit and Alternator bracket to access
and replace Timing Chain, Tensioners, One Guide in each
Cylinder Head, Oiler Tube kits, Valve Cover Gaskets and owner
supplied left Valve Cover.
Set valve and ignition timing.
Change Oil Filter
Total Labor: .........$539.00
1 Timing Chain.......$105.00
1 Chain Tensioner...$250.00
2 Guide Rails............$12.50
2 Oiler Tube Kits.......$22.00
8 Crush Washers........$4.00
1 Oil Filter................$11.50
Total Parts.............$405.00
9 Quarts 15W40 Oil...$42.75
Trans Fluid...............$1.19
MD State Tax..........$26.94
The guys at the 107 forum thought it was reasonable. I did too.
Quis custodiet ipsos custodes?
Digmenow is online now
post #2 of 3 (permalink) Old 05-03-2015, 09:40 PM
Rahj2001's Avatar
Date registered: Dec 2007
Vehicle: 98' CL500, 96' S600 coupe & the newly acquired 95' SL600
Quoted: 28 Post(s)
Excellent. I live in Severn(at least thats where my home is). When I get back to the states I will go check them out.
W215: 2000 Black Cl500 Coupe (R.I.P.)
2002 Silver CL600 Coupe miss you very much W140: 1998 Black CL500 Coupe
1996 White S600 Coupe & the newly acquired 1995 SL600
Rahj2001 is offline
post #3 of 3 (permalink) Old 07-11-2015, 04:56 PM
Date registered: Jul 2015
Vehicle: 1985 300SD, 1984 300TD
Quoted: 2 Post(s)
want to bump up the earlier recommendation for the Autohaus in Millersville. Claude maintained our cars for about 10 years in Maryland ('85 300D, SD, '84 300TD), until leaving the area about five years ago. I last talked to him about a year ago, and can't say for sure he is still at it, but absolutely recommend him if he is still there. I think we probably averaged about $1k per year for each car, getting regular service on each about every three to four months.
You have to be able to leave your car with him for a day or so, and we always cycled the three through. Really miss having the service available -- NY is probably a little out of range, but MD/DC/VA is likely in the "service area" if you can arrange to drop off the cars like we did. I guess driving 20 to 30 year old vehicles with complete confidence says something for the manufacturer (and for diesels), but have to believe most of the credit would go to the quality of maintenance and repair service received.
Diamantblau is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Recommended Repair Shops > U.S. - East
