Does anyone have a diagram of where all drains would be on a 2005 sl500? I want to make sure that none of them are clogged with debris.
You will know, as water will get inside the carDoes anyone have a diagram of where all drains would be on a 2005 sl500? I want to make sure that none of them are clogged with debris.
but none the less there are 3 critical ones, two in the rear, that you can ealisy see they Y hoses running down toward the deep ends of the trunk
The third and most common to clog is up front, by the starter battery, where the air intake vent is.
There is a tray system that separates are from liquid, with a gravity emptying this tray. if you live in an area with lots of tree droppings, the drain hose can get clogged, and water over flows, and gets into the interior by the passenger foot area.
To clean it, you need to remove the battery (remove rear first) then take the ducting box apart, and clean its drain hose that goes into the wheel well area.
