I have spent a great deal of time reviewing everything ABC on this and other forums, and yes, I know I will have to get it scanned to determine the fault codes. The amount of info is overwhelming and I'm now more confused than ever. All I'm after at this point is some insight from those who have been through this so I can have a decent conversation that isn't one sided with my indy.. and who knows, depending on the issue I may be able to follow one of the DYI's out there
So, here is the detail I know
1) Since I bought the car (October 2011) every once in a while, when opening a door after the car had been parked a while, a motorized sound came from the front end - no noticeable change of height
2) Every once in a while, sitting in the car parked with the engine running a noticeable drop to the front end happened, and it would raise back up when put back in drive (seemed like the front passenger side - but can't be sure)
3) During my spring oil change, my indy noticed a bit of 'weeping' at the lower end of the suspension at the front passenger side - said not to worry didn't look major
4)Never had any ABC warnings until last Saturday when pulling out of the garage the RED 'ABC Drive Carefully' showed up - left the car parked
5) Sunday started it up - no warnings - cycled through raising and lowering the car about 10 times, found no issues. Checked ABC fluid and it was a tad low
6) Monday, drove the car to work, no issues all 85KM. Started it up to leave work, instantly the RED 'ABC Drive Carefully' appeared, and I was driving, as others have stated, a tuna boat. Bought some fluid and topped up the ABC
7)Tuesday, drove the car to and from work - approx 170Km round trip and 5 minutes before getting home the WHITE "ABC Visit Workshop' came on, no RED warning
8) Thursday, drove the car to and from work again, this time no warnings at all, until I stopped into a store to run an errand. When I came out and started the car, instantly the RED message again. When I got home, parked the car and looked, the front passenger corner was raised while all the other corners lowered and normal. Couldn't cycle through the ride height as I guess when the RED warning is on, those functions are disabled
9) I have no noticeable leaks of fluid on my garage floor, and looking around best I can with a flashlight in the engine area and wheel wells, I see no leaks.
I'm not thinking pump, as when the RED warning is NOT illuminated, raising and lowering the car seems to be normal, which leaves block or strut, and I'm assuming it's the front passenger side causing the problem due to the 'weeping' found by my indy, and the fact that it now appears to be at max ride height when the rest of the car is lowered.
So, there you have it..... any of you out there care to suggest given your experience what the problem is ? Again, I'd just like to go to my indy prepared, so am looking for whatever feedback and info you all have.
Thanks in advance
-Stephen
Thanks in advance
-Stephen
