Arnott for a leaking rear strut? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 03-11-2012, 06:31 AM Thread Starter
Date registered: Nov 2009
Vehicle: 2003 sl 500 launch edition
Looks like my 2003 Mercedes sl 500 has a leak under the passenger side rear wheel. Afraid it’s probably the abc shock. Looking at the web i saw a new one at mbonline parts for about $1100 or i could get the rebuilt, OE front air shocks from Arnott
MERCEDES-BENZ Air Suspension Parts - SL-CLASS 2003-2006 (SL500 & SL600) R230 chassis
for $599. has anybody used these, if so what did you think?
"Arnott is pleased to offer our completely rebuilt, OE front air shocks for the Mercedes-Benz SL-Class. Each shock is painstakingly disassembled and rebuilt from the ground up. We have worked directly with one of the largest seal manufactures to design and test a nearly indestructible polyurethane seal to last for many years. Your price is only $599.00, plus a refundable $200.00 core charge (prepaid return label included). Once again, our design is not only more efficient, but it’s also much more affordable! Each shock is covered under a lifetime warranty. "
I’ve heard mb recommends you do both (car has 83k miles) but i'm pretty cheap and would really rather get by with just the one. Would this be ok?
They also have a 10% off code of 74V4-W7D.
mtbmtb is offline
post #2 of 13 (permalink) Old 03-11-2012, 08:28 PM
Dylan's Avatar
Date registered: Sep 2004
Send a message via Yahoo to Dylan
I did one of these last year. You said you have a leak on the rear but you linked to a front?
Anyways, ours was just as good as the OEM strut. We changed just the one that was bad (front right). Sent back the old for the core and got our core back, no problems. These also come with a lifetime warranty.
Great company to deal with.
You will also need to cycle the system through the "rodeo mode" to bleed the system. some say you can just cycle up and down though the heights but I have a SDS so I ran the rodeo myself.
The front strut only took me 20 min to change.
Dylan is offline
post #3 of 13 (permalink) Old 03-12-2012, 08:44 AM Thread Starter
yea i need the rear, but all their description say front on the website even when describing the rears.
my nephew is in the air guard with a guy that is a service tech at the local mb dealership so i get him to do all my work on the side. he has access to all the computer stuff. still waiting to find out if it's the shock or the hose. thanks for the reply.
mtbmtb is offline
post #4 of 13 (permalink) Old 03-14-2012, 10:08 AM
Date registered: Aug 2010
I replaced the right front one with an Arnott 2 years ago....works perfectly. I did have to top the ABC fluid off after a week to get the light to stay off.
I'm sure there will be more to come in my future.
GB1099 is offline
post #5 of 13 (permalink) Old 03-18-2012, 04:11 PM
PLeeson's Avatar
Date registered: Apr 2007
Quoted: 5 Post(s)
I did the right rear last fall.
The Arnott Part # is SK-2414
It was actually pretty easy; moving the exhaust out of the way was the only hard part.
I did it on the floor with 2 jacks and 2 jack stands.
No need to replace both of them.
Agree with others that the Rodeo procedure is needed.
I also flushed the system and replaced the fluid.
Amazing how well that car rides/handles now...
Phil
Prior MBs:
1971 250, 1983 380SEL
1986 190E2.3, 1987 300TD
1994, 2003, 2005 SL500s
2001 E320 4Matic
2011, 2012 E350 4Matics
2012 S550 4Matic
PLeeson is offline
post #6 of 13 (permalink) Old 03-18-2012, 07:18 PM Thread Starter
so when you flushed the fluid, how much chf 22 did you use? i am lucky in the my nephew is in the air guard with the local mb dealers best tech so i get him to do the work on the side. he said to really flush the system you need 10 quarts even though the specs only show it holds 5. he said it takes 3 to replace the shock so i went with 3. do plan on changing the filter out. btw autohausaz has it for $16+/qt.
mtbmtb is offline
post #7 of 13 (permalink) Old 03-19-2012, 08:50 PM
PLeeson's Avatar
Quoted: 5 Post(s)
I did 3 and saw a big difference.
The filter change and rodeo are actually the main things that help.
Phil
Prior MBs:
2001 E320 4Matic
2012 S550 4Matic
PLeeson is offline
post #8 of 13 (permalink) Old 11-15-2012, 03:04 PM
Date registered: Apr 2011
my left front and left rear struts are leaking, are these hard to replace by oneself?
I am not the most mechanical person but I am somewhat inclined.
thx
Acemanti is offline
post #9 of 13 (permalink) Old 11-18-2012, 08:54 AM
Date registered: Oct 2008
Vehicle: 11 Mustang Convert,.87 El Camino,09 Avalon Limited,05 GMC Sierra Denali, hunting AMG car.
partsgeek.com sells Arnott struts for $399 with same core charge,same lifetime warranty;FYI. Best of luck.
bighart is offline
post #10 of 13 (permalink) Old 11-18-2012, 05:40 PM
Richrider's Avatar
Date registered: Jan 2012
Vehicle: 2005 SL 500, mileage 85K
Quoted: 10 Post(s)
Send a message via AIM to Richrider
Go with the Arnott struts. I replaced the the one leaky rear strut myself. Sure enough the other one went out a few weeks later. My advice is do both, it's only a matter of time before the other goes. You only have to do the rodeo once and it's over, until the front ones start to leak. Like the other writer indicated, the exhaust is the only troublesome obstacle, not rocket science just a little time consuming the first time. You'll need a couple specialty sockets, cost about $10, if you don't have them in your tool box.
Richrider is offline
    Arnott Strut purplebenz2000 W220 S-Class 3 08-15-2011 05:48 PM
    Need help removing rear strut. Arnott replacement waiting to go in. zerker W220 S-Class 5 01-01-2011 11:36 PM
    Arnott Ind. Rear Strut Replacement Issues zerker W220 S-Class 0 12-28-2010 02:12 PM
    1998 sl600 strut leaking DUFFS3169 R129 SL-Class 10 05-10-2010 06:36 AM
    '06 R350 Front Air Strut Leaking... clscruizer350 W251 R-Class 0 06-25-2009 11:32 PM
