2004 SL55 Glove Box Latch/Strike - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-28-2011, 10:01 PM Thread Starter
Date registered: Jul 2009
I have searched all the posts and cannot find this problem discussed.
I have a glove box door that will not stay closed.
I successfully removed the entire glove box from the car.(quite a feat for a non-DIY guy). The latch mechanism works fine. Something was rattling from inside the glove box door. I turned the glove box upside down and the metal strike that is inside the door came out along with a tiny torx screw.
Question: Can you remove the front leather fascia off the glove box door to reinstall the strike? If so, how? If not, do I have to buy an entire new glove box? There does not seem to be way to remove the door from the actual box.
Any help would be appreciated.
Thanks
SL_55_AMG_AZ is offline
post #2 of 4 (permalink) Old 11-04-2011, 01:00 PM Thread Starter
Hello to all;
After taking the entire glove box into the dealer; they were stumped. They had never seen the strike plate fall off inside the glove box door. Mine was a first. The choice was to buy a new glove box or take it home and devise a solution.
After many hours and the use of a lot of surgical instruments, I used JB Weld to secure the latch back in place without tearing the glove box door apart.
It can be done but I do not wish it on anyone!
post #3 of 4 (permalink) Old 10-21-2013, 11:50 AM
Date registered: Oct 2013
Vehicle: SL55
Urghhh I'm in the same situation
Originally Posted by SL_55_AMG_AZ View Post
Hello to all;
I recently had my glove box break down on me as well, i had removed the entire glove box from the car, managed to remove the lid from the glove box, but as you stated, it appears to be no way possible to remove the leather from the plastic backing. The bracket is rattling around inside and I can't manage to get it out. Do you have any suggestions? I'm looking everywhere and can't find any info on separating the lid apart.
HFELIU is offline
post #4 of 4 (permalink) Old 10-21-2013, 03:32 PM Thread Starter
There is no way to separate the inner and outer door of the glove box. Have a lot of patience and you can glue the strike back in place.
CLK-320 Glove Box Latch jodellking General Mercedes-Benz 2 01-10-2015 06:16 AM
Glove Box Latch Broke Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 4 07-26-2011 04:12 PM
Glove Box Latch.... all2nvious R170 SLK-Class 3 06-07-2011 01:32 AM
Glove Box Latch crjc W123 E,CE,D,CD,TD,TE Class 3 04-25-2011 07:50 PM
Glove box latch IanManchester R230 SL-Class 11 08-04-2010 01:19 PM
