Safe lifting points with a floor jack? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-23-2011, 12:41 PM Thread Starter
falconsprint's Avatar
Date registered: Sep 2005
Vehicle: 2009 SL65, 1998 CL600 (sold), 1989 560SEL (sold)
I know about the four lifting points on the side of the car. But I like to put my jack stands under those. Is it safe to lift a R230 from the cross member under the engine? There is a hard plastic bumber in the center that sticks out from the shield. I assume this was put there as a lifting point. Can somoene confirm? Is it safe to lift the rear of the car from the rear differential?
falconsprint is offline
post #2 of 8 (permalink) Old 04-23-2011, 01:29 PM
Date registered: Aug 2008
Quoted: 36 Post(s)
under a 4 jack points, the flat pad
okbarnett is offline
post #3 of 8 (permalink) Old 04-25-2011, 11:26 AM Thread Starter
Can anyone confirm that it is safe to lift the car from the front cross member and rear differential?
post #4 of 8 (permalink) Old 04-26-2011, 11:03 AM
Minty's Avatar
Date registered: Nov 2005
Vehicle: SL55 AMG
Send a message via MSN to Minty
I've always wondered this as well as i like to support the car with an axle stand as well as the trolley jack. Couldn't really find anywhere that looked great to put it but i usually just place an axle stand near the jacking point for safety in case the trolley jack gives way.
Minty is offline
post #5 of 8 (permalink) Old 04-27-2011, 04:13 PM
RickP330's Avatar
Date registered: Nov 2008
Vehicle: 2008 C300 Sport (W204) Retired, 2014 C250 Coupe Retired, 2017 C300 coupe & 1998 SL600 Sport (R129)
Quoted: 5 Post(s)
I dont know if it applies here but this is what we are doing on the 129 forum.
http://www.benzworld.org/forums/r129...ck-points.html
I am making a similar fixture and will post later this week. hth.
Rick
RickP330 is offline
post #6 of 8 (permalink) Old 04-27-2011, 04:56 PM
JBow's Avatar
Date registered: Jun 2010
Vehicle: 2002 CLK 430 1999 ML 320
I would not do it. It is to easy for the jack to slip and do major damage. Only lift from the proper locations.
Jack
2002 clk 430
1999 ml 320
1998 VW beetle - SOLD
1999 E250 - SOLD
1970 Scat-Craft / 115 Merc - SOLD
1960 F-100 - SOLD
1985.5 Porsche 944
1984 Lincoln Mark VII custom
JBow is offline
post #7 of 8 (permalink) Old 04-27-2011, 05:29 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
My W209 has an identical front jacking point (block) located in the center of the front cross traverse of the front axle carrier. The jack must be capable of lifting 2 - 3 tonnes. My WIS confirms this place for the W209. Your model is not covered in my WIS, but as you have the same feature, it must be the front jacking point.
About the rear, the WIS drawing shows lifting at the diff. It might seem surprising, but there is not much weight at the rear of the car. I would use a block of wood over the top of the jack.
I assume that you are not going to work under the jack. It is only to get the jackstands in place, right?
keyhole is offline
post #8 of 8 (permalink) Old 04-27-2011, 07:23 PM Thread Starter
Thanks, this is the confirmation I was looking for. Don't worry, I have a made in the USA Lincoln floor jack and I've lifted many cars over the years. I always use jackstands. The jackstands I like to use for Mercedes have flat tops and fit perfectly under the four rubber jacking points on the sides. As I've stated in my first post, the problem with lifting the car from the four side lifting points is that I can't put my jackstands under those points if I'm using them for the jack.
    Lifting car with floor jack. Bests points for jack and stands? DirtyD W203 C-Class 6 07-19-2010 10:22 AM
    Lifting a 406 with a floor jack under the differential a bad idea? MegaMog Unimog 14 01-06-2010 09:47 AM
    Floor Jack Points larryk R170 SLK-Class 3 07-09-2005 07:54 AM
    are the rubber mounts (floor jack points) under the rocker panel replaceable? rbridges R170 SLK-Class 3 03-30-2005 10:11 PM
    lifting points Lone Star SL500 R129 SL-Class 2 11-13-2004 12:46 PM
