Power Steering fluid - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-18-2010, 12:34 PM Thread Starter
Date registered: Feb 2010
Vehicle: 2004 SL55
The fluid required by the power steering pump and I believe the ABC system was quoted by my dealer at $60 for a small container. I found that the local NAPA store sold Pentosin CHF 11S for $21/liter. A Volvo dealer also sells is for about $25.
busaboy is offline
post #2 of 9 (permalink) Old 02-18-2010, 12:38 PM
mkirincic's Avatar
Date registered: Aug 2008
Vehicle: 2003 SL500;1998 E320 Wagon
Quoted: 2 Post(s)
Check out ebay. I was able to purchase a pint for $11 and $4 shipping. This was the same product that MB was selling for $60 a pint.
My $.02
mkirincic is offline
post #3 of 9 (permalink) Old 02-19-2010, 10:50 AM
bltserv's Avatar
Date registered: Feb 2004
Vehicle: Sold my 2005 SL55, 2000 CL500
I use the stuff they have at Napa on my SL55 and my CL500.
Just make sure its the CHF11S Pentosin in the Green Can.
bltserv is offline
post #4 of 9 (permalink) Old 02-24-2010, 06:01 AM
Date registered: Sep 2007
Vehicle: 2013 E350 Black over Tan; 2015 Corvette Stingray Z51 Coupe
Quoted: 2 Post(s)
Power Steering Fluid/Reservoir Question
The 2005 SL500 manual makes no mention of the PS reservoir or fluid except to list the fluid in the specs.
Just to be sure.....I think the PS reservoir is right behind the ABC control unit. The very short "stick" in the cap is not showing fluid at all when the car is cold.
Is it time to add some CHF 11S Pentosin from NAPA ?
Any advice will be helpful.
Thanks in advance
*2013 E350 -Black over tan
*2015 Corvette Z51 Stingray Coupe-Grey over Kalahari leather
Boston Joe is offline
post #5 of 9 (permalink) Old 02-24-2010, 06:24 AM Thread Starter
Vehicle: 2004 SL55
The level should be at the correct on the stick. The stick is graduated by 4 lines and two temperature ranges. The lower lines are the high/low level for cold/ambient and the upper lines are for when the fluid is hot. It is a little confusing for some. To make it easy, check the fluid when the car is cold. Just be sure your fluid is showing on the stick and not too high or too low. So yes add fluid.
My 2004 SL55 had only 3500 miles so low PS fluid was not something I would have looked for. There was a stored PS fluid fault that my buddy found when scanning my car with a special diagnostic tool. He had to clear a bunch of faults I assume were due to the car sitting for a very long long time with dead batteries. Most of the faults were never displayed. The big red battery fault that required you to go to a dealer was the one I wanted cleared. He found a bunch of stored faults for virtually every system in the car. I wanted all cleared to see if any come back. My next goal is to get the SOS and Phone systems disabled. Im looking for a shop that can do that. My buddy does not think his tool can do it.
busaboy is offline
post #6 of 9 (permalink) Old 02-24-2010, 06:49 AM
Quoted: 2 Post(s)
Found local NAPA has it for $21 so I'll get some and add a litle at a time when cold to hit the lower two hashmarks.
Thanks for the advice.
Joe
post #7 of 9 (permalink) Old 02-26-2010, 03:32 AM
Quoted: 2 Post(s)
Smile
Had to buy the liter can for $20.99 + tx. Reservoir needed only about 2-3 ounces to hit the hashmarks on the short stick.
The rest of the can will sit on the garage shelf for a long time.
post #8 of 9 (permalink) Old 02-26-2010, 06:56 AM Thread Starter
Vehicle: 2004 SL55
I believe the ABC system uses the same fluid. You may need to top off it at some future date too. It won't be wasted.
busaboy is offline
post #9 of 9 (permalink) Old 12-31-2011, 07:31 PM
Date registered: Oct 2011
Vehicle: 2008 mercedes suv
my 2000 s430 is low on power steering fluid. can i use the CHF11S Pentosin from napa to top it off??
2008 rl
atldeville is offline
    Power Steering Fluid or Hydraulic Fluid? Luke1 W140 S-Class 2 12-31-2009 07:26 AM
    '99 ML430 Power steering fluid leak from steering rack boot? XxAndrijanXx187 W163 M-Class 15 10-26-2009 04:54 PM
    Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 10:59 AM
    Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
    Hydraulic Fluid/Power steering Fluid panzerwagon_350slc General Mercedes-Benz 4 09-07-2005 10:06 AM
