» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R230 SL Class
Old 11-04-2009, 08:09 PM   #1 (permalink)
Date registered: Nov 2006
sl 500 03 problems need help please
well I was driving home tonight after dark and all of my lights go off. pretty scary. anyway pulled over and the battery light visit workshop is flashing along with bas, and esp. well I restart the car but no lights and transmisson will not go into gear? so i left it on the side of the road and got a ride home. went back and ck the voltage on both batteries and they are both @ 13volts. ? anybody got any ideas?? maybe a fuse or something ?
mbgta is offline   Reply With Quote
Old 11-05-2009, 05:23 AM   #2 (permalink)
I went back and got the car. It started but no lights and only 1st gear was available . Got it home in the garage and malfunction display says abs, showing battery light and esp, and bas sytems problems? Any ideas anybody ?
Old 11-05-2009, 05:47 AM   #3 (permalink)
Date registered: Jan 2004
Vehicle: SL500, 300SL, 500SL
I will guess that the problem is either the main fusebox is not receiving power or the Signal Acquisition Module (SAM) located beneath it is bad. The fusebox is easily checked with your voltmeter; the SAM is quickly and easily checked with Star Diagnosis. You can purchase your own SDS from Chinese eBay sellers for about $800.
Many used parts available from a '92 SL. Email or PM for more information
bobterry99 is offline   Reply With Quote
Old 11-05-2009, 10:19 AM   #4 (permalink)
I got it towed to a local benz mechanic, He is looking at it and I will let you know what they find. Thanks for the reply !!
Old 11-08-2009, 08:40 AM   #5 (permalink)
update::: Good news on the car. Took it to the mechanic and he diagnosed it as a bad voltage regulator. The alternator was putting out over 18 volts to the cars's systems and the computer shut the tranny off as well as the lights and esp systems as well as the braking sytems. It set 7 malfunction codes. Crazy ! Anyway $60 voltage regulator fixed the problem and the car is back working perfect. Sweet !!!
Old 11-11-2009, 08:10 AM   #6 (permalink)
Carlo$'s Avatar
Date registered: Sep 2003
Vehicle: 97 SL500
Dude, never leave your car on the road! spend $100 in towing if necessary.
http://xrl.us/benz1
Carlo$ is offline   Reply With Quote
Old 11-12-2009, 07:21 PM   #7 (permalink)
Date registered: Dec 2007
Vehicle: 2003 SL500, 2005 ML500SE
'Nuff said
egwu is offline   Reply With Quote
Problems with my 06 ML 500 06ML_500 W164 M-Class 9 02-27-2009 04:57 PM
500 SL electrical problems bryn_p R129 SL Class 2 01-13-2009 07:50 PM
G 500 got problems ? balticstone G-Class 14 05-11-2008 07:27 PM
roof problems with my SL 500 arjan R129 SL Class 1 08-05-2006 10:04 AM
1995 SL 500 Problems black SL500 R129 SL Class 8 02-20-2004 10:06 PM
