» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R230 SL Class
Old 10-19-2009, 06:52 AM   #1 (permalink)
Date registered: Oct 2009
Vehicle: 2004 SL500
SL500 Steering Fluid
help! can anyone tell me where to check the power steering fluid level and/or where to put the fluid in my 2004 - SL500?? please be specific! Thank you.
-- Photo attached of what I see under the hood! Thanks again if anyone can direct me to the right spot
Last edited by ldallas : 10-19-2009 at 10:30 AM. Reason: photo attached/title update
ldallas is offline   Reply With Quote
Old 10-19-2009, 07:56 AM   #2 (permalink)
msbarsi's Avatar
Vehicle: 2000 Obsidian Black Metallic Mercedes SL 320 V6
Hi ldallas and welcome in our big and friendly international family. Please remember to update your profile with your car year and location to help us help you in the best and quickest possible way.
Back to your problem, you are in the wrong sub forum since your car is an R230 and not an R129 so you should post your question in the R230 sub forum.
Cheers.
I drive like I stole . . . YOURS
msbarsi is offline   Reply With Quote
Old 10-19-2009, 09:13 AM   #3 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, CL55, LS430, CAMRY
It should be next the to ABC reservoir if you have ABC. If you look at your car front the front, it should be on your right right behind the headlight.
lnguyenh is offline   Reply With Quote
Old 10-19-2009, 09:21 AM   #4 (permalink)
lnguyenh's Avatar
The picture is on a CL (same location on all CL W215 models) but your car should be similar. The smaller container is the reservoir for the Power Steering. The bigger one is for the ABC.
Old 10-19-2009, 01:37 PM   #5 (permalink)
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 95 SL500: 6700 RPM, K&N, Custom Intake, Ported & Polished TB, RENNtech RB, AMG I Monoblock
Hi ldallas, and welcome aboard BenzWorld.
Please note that I have moved your post to the R230 sub-forum where it would better suit this topic.
Best Regards,
1/4 Mile ET: 14.036 @ 100.49 mph
NEOKEN is online now   Reply With Quote
Old 10-19-2009, 01:40 PM   #6 (permalink)
NEOKEN's Avatar
Correct.
'97 SL500 / Where do I add the power steering fluid? scott1 R129 SL Class 2 12-19-2007 02:18 PM
'97 SL500 / Where do I add the power steering fluid? scott1 R230 SL Class 0 12-19-2007 10:46 AM
Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 10:59 AM
Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 08:12 AM
Hydraulic Fluid/Power steering Fluid panzerwagon_350slc General Mercedes-Benz 4 09-07-2005 10:06 AM
