» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Roadster Forums > R230 SL Class
Old 06-27-2009, 07:31 PM   #1 (permalink)
Date registered: Jan 2009
Vehicle: 2003 SL 500 Sport, 1998 Ferrari F355, 1999 Lexus GS400, 1981 DeLorean DMC-12
Brake Fluid Low warning light?
I got a warning light on my car today. It came on after it had been sitting all day. It says "Brake Fluid Low visit workshop". I checked the brake fluid and it is full. Any ideas?
I have a warranty its just a PITA to take the car in.
-Chris
DeLorean00 is offline   Reply With Quote
Old 06-28-2009, 01:35 AM   #2 (permalink)
Date registered: Jan 2004
Vehicle: SL500, 300SL, 500SL
The level is sensed by a switch that is closed when fluid is low and open when it is not. The switch plugs into an electrical connector located at the top of the reservoir.
I suggest unplugging the switch and seeing if the warning indication disappears.
Many used parts available from a '92 SL. Email or PM for more information
bobterry99 is offline   Reply With Quote
Old 06-28-2009, 12:21 PM   #3 (permalink)
I tired unplugging it. No luck, same warning. The guy at MB Roadside said that it would get stored in the computer unless cleared at the dealer. I thought it was a bit odd that it would get stored.
But as always, who knows if he knew what he was talking about.
Old 07-01-2009, 04:53 PM   #4 (permalink)
As I suspected the sensor in the brake fluid reservoir failed. My warranty is taking care of it, along with some ball joints the dealer said need replacing.
Coolant LOW Warning Light SL32WA R170 SLK Class 15 10-22-2008 06:26 AM
Low Fuel warning light always on njview W123 E,CE,D,CD,TD,TE Class 7 08-26-2007 09:47 AM
low brake fluid light blinking skipinschool W210 E-Class 17 05-28-2007 02:19 PM
Low Coolant Level Warning Light, but fluid is full ksing44 W124 E,CE,D,TD Class 1 09-05-2005 03:55 PM
Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK Class 3 03-21-2001 04:28 PM
