Changing the clock - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-17-2009, 06:14 AM Thread Starter
Date registered: Jan 2009
Vehicle: 2004 sl55 AMG
Changing the clock
I give up! Have been trying to change the clock on my new 2004 sl55. I go into the command center system settings Date/Time...select country USA...scroll down to Central time zone...press scroll button which takes me to check Auto daylight savings time...and then what do I do? When I press enter from the scroll button it only checks of unchecks the daylight savings time options...so I press SAT and it goes back to eastern seaboard time!!!! I have tried setting the clock time manually and it updates itself based on the SAT radio which thinks it is on eastern seaboard time. HELP! What am I doing wrong?
hegarty@mail.utexas.edu is offline
post #2 of 12 (permalink) Old 03-17-2009, 06:45 AM
Date registered: Jul 2006
Vehicle: 2005 SL500 Iridium Silver/Ash with wood trim upgrade...
Are you trying to change the little dash clock or the system clock displayed on the COMAND screen?
COMAND Screen: This clock is automatically updated from the satellites based on the region you specify in the settings. Depending on your "Convenience Settings", the dash clock will be synchronized with this clock. To save the settings you pick on the COMAND screen, it is best to use the "OK" button in the middle of the directional pad.
Dash Clock: This clock can be set separately from the COMAND clock if you use your steering wheel buttons to navigate to the "Settings" menu in the speedo screen. Under the Convenience features, there is a clock menu item. Selecting it will give you "Set Clock Separately" (or something like that) with YES/NO choices. If you set to NO, then you can set your dash clock independently within the speedo menus. I had to do this because the COMAND clock was 10 minutes fast compared to the clocks at work... Don't ask!
Also keep in mind that the daylight savings time change date has been changed recently, so you may need to check/uncheck the DST setting as appropriate to your area.
I hope this helps.
Rook
Rook3001 is offline
post #3 of 12 (permalink) Old 03-17-2009, 07:07 AM Thread Starter
Thanks for your guidance. I am trying to set both clocks actually. I'll give the procedures you suggest a try. I think my problem is that when I leave the daylight saving screen there is no "enter" button. Never noticed an "ok" button but I'll look for it. What you say makes sense since the system acts like it never accepts my changes. Thanks again, most helpful!
post #4 of 12 (permalink) Old 03-17-2009, 08:41 AM
No problem, glad to help.
By the way, the OK button is an actual button on the COMAND console. It should be the center circular button in the middle of the directional keys at the bottom right of the COMAND console. You can see it in this picture (on the far right side):
Rook
Rook3001 is offline
post #5 of 12 (permalink) Old 03-17-2009, 08:52 AM Thread Starter
Ah, now I know why I never noticed it. My 2004 command consol looks different that the one in the picture (see attached).
post #6 of 12 (permalink) Old 03-17-2009, 10:12 AM
Wow, woodja look at that. You're gonna have to refer to your COMAND manual for assistance with that one, unless someone else here has the old style COMAND console and knows how to set the clock on it.
Good luck.
Rook
Rook3001 is offline
post #7 of 12 (permalink) Old 03-17-2009, 12:16 PM
Fehmarn's Avatar
Date registered: Aug 2007
Vehicle: '04 SL 500; '05 SLK 350
Go to the "SYS" menu, chose "date/time"
Now either activate or deacitve automatic updates and automatic DST in the menu.
Press the right button longer than two seconds to save your changes.
If you want to set the time manually scroll to the time (hrs or mins) using the right button. Once the item you want to change is under the cursor, press the right button. The display color of the item changes to red, now you turn the right button again to reach the desired setting and press it again - for more than two seconds - to save what you have changed.
The system should update time and date from the GPS-signal - check your settings first, seems to me something is off with yours.
Fehmarn is offline
post #8 of 12 (permalink) Old 03-17-2009, 01:20 PM
Hal Adams's Avatar
Date registered: Oct 2007
Vehicle: 07 SL350, 14 BMW320, 05 SLK and 4.6 MGBV8
This is the classic reason we should put the car year and model into our profile, yes?
The moderators on the 129 forum insist on this and check us up when we post without year and model. we should do the same, but I note that the 230 forum does not have a moderator...
Hal Adams is offline
post #9 of 12 (permalink) Old 03-17-2009, 01:37 PM
Agreed.
*looks left*
*looks right*
Sounds like you just volunteered Hal! LOL
Get to work!
Rook
Rook3001 is offline
post #10 of 12 (permalink) Old 03-17-2009, 02:01 PM
Hal Adams's Avatar
Why did I think as soon as I hit 'post' that this would be the reply...!
Not for me, I am not well enough versed on the cars is my excuse - plus I only have the entry model. I think the ideal moderator would have at least a 500...
He says, fast exit left.
Analog clock not synchronized with digital clock remedu W211 E-Class 17 12-29-2009 08:53 AM
Changing the time on the dash clock Bwbigdog W211 E-Class 7 11-10-2007 07:49 AM
01ML clock changing, DST lastprodigy W163 M-Class 7 03-13-2007 01:22 PM
A saw an AMG wall clock yesterday. The clock was mounted on ..... Beng R170 SLK-Class 16 01-10-2007 11:01 AM
It say's clock clock clock when I'm turning andreas G-Class 2 05-01-2003 06:54 PM
