How to fill hydraulic pump - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-04-2008, 04:12 PM Thread Starter
Date registered: Oct 2008
I would appreciate any help with directions on how I fill the hydraulic roof pump. I have just about completed the painstaking replacement of the top attachment latch cylinder after a huge leak, and I have the correct fluid, but its a mystery on how to correctly fill the pump back up. Thanks!!
billtodd is offline
post #2 of 6 (permalink) Old 10-05-2008, 09:12 PM
Date registered: Jan 2004
Vehicle: '03 SL500, '91 300SL, '91 500SL, '00 S500. '98 E320, '96 C220
Quoted: 131 Post(s)
You remove one of the two screws shown in the picture -- I don't remember which one, but it may be obvious -- and then you inject fluid using a syringe.
bobterry99 is offline
post #3 of 6 (permalink) Old 10-07-2008, 07:54 AM Thread Starter
Thanks.... I used a small funnel. worked great.
billtodd is offline
post #4 of 6 (permalink) Old 02-02-2010, 07:01 PM
ttdang123's Avatar
Date registered: May 2009
Vehicle: 2004 SL600 with Mods; 2003 F 360 Spider
Send a message via Yahoo to ttdang123
I am trying to check and fill my roof top hydraulic fluid.
I found this old threat and the two attached docs. I am still not quite clear on which screw (top or bottom) I can open to add the fluid?
I opened the top screw and fluid came out. I then removed the bottom screw but could not force any fluid in (I am using a store bought syringe - non MB part). Did anyone preform this process and could give some tips? Would appreciate the help.
Thanks in advance
ttdang123 is offline
post #5 of 6 (permalink) Old 06-12-2010, 05:46 AM
Date registered: Apr 2010
Dear experts!
when the vario roof is totaly down in the trunk lid where should be the level of oil in the hydraulic pump reservoir?anybody any idea?
leventisp is offline
post #6 of 6 (permalink) Old 06-12-2010, 05:53 AM
eric242340's Avatar
Quoted: 296 Post(s)
Originally Posted by leventisp View Post
Dear experts!
Look at link 2 and the little X in the photo marks the spot where the level should be with the roof UP. Down is not a of any interest, as long as it meets the level when up.
ERIC.
eric242340 is offline
    PTO hydraulic pump mogish Unimog 17 07-04-2008 10:50 PM
    hydraulic pump spantyboy Unimog 1 03-06-2008 11:07 AM
    where is the hydraulic pump for softop? 1992300SL R129 SL-Class 4 02-06-2008 01:00 PM
    hydraulic suspension pump miki_com_au W126 S,SE,SEC,SEL,SD,SDL Class 2 12-18-2006 07:17 AM
    Anyone know how to fill Hydraulic Fluid for ROOF? zanshadow R170 SLK-Class 1 04-04-2004 05:44 AM
