Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R230 SL Class
Old 07-01-2008, 10:25 AM   #11 (permalink)
Date registered: Dec 2007
Thank you for the information. That PDF file is incredible. I really appreciate that. The SL is at the Dealer's as I write this...took it in this morning. So far, the dealer isn't quite sure, but the tech "thinks" he found a leaking piston in one of the pumps ( I called for a progress report). We'll see.
Thanks again for the input.
Stan
spilok is offline   Reply With Quote
Old 07-02-2008, 04:20 AM   #12 (permalink)
Well....Good news. The Dealer found the culprit. Indeed, the Left vario roof (open/close) hydraulic cylinder showed evidence of leaking. It seems that the piston appeared rusty and the seal was cracked. Using a dental mirror, after exposing this piston in its awkward position, they were able to see the leakage. However, there is no puddle beneath it so somehow the minute amounts of hydraulic fluid somehow escaped this area.
How did this happen? Don't know. This car, though sat unused for quite a long time. I bought it with less than 8000 miles on it last year, and the previous owner had 10 cars in a thermostatically-controlled garage. I'll never know how it happened, but at least I will have a good summer without fear of the top freezing in half-opened position.
Thanks for all your suggestions and help.
Stan
Old 08-22-2008, 12:15 PM   #13 (permalink)
Date registered: Nov 2005
Vehicle: 2003 SL350
Originally Posted by spilok View Post
No one seems to be replying to this. That's OK. I think I found out the answer to my problem today. Low hydraulic fluid in the trunk where the hydraulic container is located. Why? Still don't know. It's going to the Dealer on Thursday. We'll see.
Stan
I am having the same problem. Can you tell me exactly where the hydraulic container is located? Thanks!
tanmervin is offline   Reply With Quote
Old 08-22-2008, 01:51 PM   #14 (permalink)
Date registered: Jan 2004
Vehicle: 300SL, SL500
Stank (spilok) started this thread on another forum: My hardtop goes up & down "sluggishly"! - MBWorld.org Forums. It shows the location of the pump and describes a procedure that may help a slow-moving top. If that does not help, then the first step would be to check the system hydraulic pressure. To do this you need a liquid pressure gauge and an adapter from Mercedes to connect the gauge to the pump. The adapter part number is 230 589 07 63 00 and costs about $20. The pressure from the pump should be around 150 PSI, if I remember correctly.
For Sale: Carsoft code reader for '94-'01 models. Non-multiplexer. Email or PM for details.
bobterry99 is offline   Reply With Quote
Driving More Slowly? tankman R171 SLK Class 14 05-06-2006 06:46 AM
Goes into reverse very slowly JBR R/C107 SL/SLC Class 4 11-16-2005 04:26 PM
Slowly turning into a 1991.... Benzonline W126 S,SE,SEC,SEL,SD,SDL Class 13 04-30-2005 10:50 PM
accelerate slowly NewBuyer G-Class 4 07-14-2004 10:47 AM
Slowly coming together 888E500 W211 E-Class 1 01-28-2004 03:01 AM
