Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R230 SL Class
Old 06-05-2008, 06:02 AM   #1 (permalink)
C1K
C1K's Avatar
Date registered: Mar 2006
Vehicle: Mercedes CLK 320 Mercedes 500SL
Folding/dipping mirrors.
Hello
2 questions , if someone could assist me I'd be really grateful.
1. how do you get the left (for uk) hand side mirror glass to 'dip' when one engages reverse.
2. how does one instruct the car to fold the mirrors in everytime I lock up with keyless go?
Yes. I have read and followed the instructions in handbook but its really confusing...please someone tell me in idiot language
finally - i lied...3 questions...your reading this so please feel free to input further on this silly query
3. when you use the key fob in the dark, the locator lights come on...but with keyless go...they dont...silly question - is this becuse you found the car in order to open doors so locator lights dont come on...?
C1K is offline   Reply With Quote
Old 06-13-2008, 11:25 AM   #2 (permalink)
Date registered: May 2008
Vehicle: 2005 SL500
I had the same issue with my SL, I thought I'd turned it on by going to the Settings menu and ensuring that, under the Convenience sub-menu, the "Mirror setting when parking" was On. However, the bit that I'd missed was "Storing exterior rear view mirror parking position" (p. 121 in my manual) and you have to do that for each key (assuming you have Key-dependent On), otherwise when you select reverse, the mirror 'moves' but doesn't actually go anywhere.
Oh, and you also have to have the Passenger-side exterior rear view mirror button in the center console pressed, for the mirror to dip when you select reverse.
johns13 is offline   Reply With Quote
Old 06-13-2008, 10:36 PM   #3 (permalink)
Date registered: Sep 2006
1. on the '08, mirror does not dip.
2. on the '08, mirrors do not fold.
On the 07 GL, it does both. Oh well.
<img src="http://banners.wunderground.com/banner/gizmotimetempbig_both/language/www/US/CA/San_Diego.gif"</a>
08 SL55 AMG Pewter
07 GL450
teeth is offline   Reply With Quote
Old 06-14-2008, 12:23 AM   #4 (permalink)
Date registered: Mar 2004
Vehicle: W203 modified
Send a message via MSN to miroj Send a message via Skype™ to miroj
Hello
1) Make sure you have the left mirror selected in the adjustment dial (the left mirror adjustment must be preselected for the dipping function to work). Assuming your cluster setting is correct.
2) Should be a cluster setting.
3) Only the key-fob activates the lights. If you open the door with keyless go then you have already located the car.
Modz ... enjoy the difference. www.benzmodz.com
miroj is offline   Reply With Quote
Old 06-18-2008, 08:07 AM   #5 (permalink)
C1K
C1K's Avatar
Thanks you guys...
1 and 3 sorted...having issues with 2.
Old 06-19-2008, 01:20 AM   #6 (permalink)
Thanks you guys...
Door controllers need some additional coding in that case. May not be activated for aut-folding. I am assuming that you can fold them with a button press and that you would like it automatic.
I did hear of a case where a technician activated the function and then it didnt work. I later found out that the car was not fitted with the related parts.
In this case I would assume there is something not coded. Look in the preferences inside the cluster.
Folding Mirrors jrgthird W163 M-Class 7 08-14-2007 08:29 AM
Auto-Dipping Wing Mirrors gibbsy W209 New CLK Class 1 09-11-2006 12:57 PM
folding mirrors? mrfredsporty W203 C-Class 1 06-01-2006 06:22 PM
Folding mirrors SirOracle W168 A-Class 1 01-10-2006 06:09 AM
Folding mirrors...... Iwan W163 M-Class 2 03-14-2002 03:56 AM
