Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Roadster Forums > R230 SL Class
Old 03-12-2007, 04:45 PM   #1 (permalink)
Date registered: Aug 2004
daylight savings time
Did everyone's clock get screwed up by the time change? Will MB issue a software fix?
I live in California, and had to set my time to Mountain time to get the correct time.
2004 SL 500 is offline   Reply With Quote
Old 03-12-2007, 06:20 PM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 2004 SL 500
Just manually reset the clock ahead one hour.
dragoncoach is offline   Reply With Quote
Old 03-12-2007, 07:40 PM   #3 (permalink)
Willy C's Avatar
Date registered: Jul 2006
Vehicle: 2003 SL500, Firemist Red, Distronic, Keyless Go, Parktronic, Bi-Xenons, Comfort & Wood Trim Packages
This may be a stupid question, but I've searched my 2003 SL500 manual and can find no instrutions on how to change the time manually.
It seems to be integrated with the GPS satellite time. I suppose the satellites' broadcast something like a universal Greenwich time and the car's GPS is then able to set the correct time by figuring out what time zone the car in, but obviously it doesn't understand the latest DST change.
Willy C is offline   Reply With Quote
Old 03-13-2007, 09:59 AM   #4 (permalink)
Dragon, I did set the time manually. But if you noticed, prior to this year, it was unecessary to set anything at all, it was pure automatic and would switch for you. Was hoping MB could release a software fix which would bring it back to that. If anyone has info on this, let me know.
Old 03-13-2007, 12:02 PM   #5 (permalink)
I know. I also hope there is a fix coming out. But until then, I'll just set it manually (four times a year). It's only a minor convenience I can live with.
Old 03-22-2007, 11:34 AM   #6 (permalink)
Date registered: Mar 2007
Vehicle: Black 2008 ML63
You have two options. You can either have the clock sync with your Command Center/GPS, or manually set it which is what I suggest. You can set it through menu options on the steering wheel control buttons and set it at "no" when asked if you want it to sync with the system.
Bijan is offline   Reply With Quote
Old 03-30-2007, 09:38 PM   #7 (permalink)
TobiasSanDiego's Avatar
Vehicle: 2003 SL55 AMG
Send a message via AIM to TobiasSanDiego Send a message via Yahoo to TobiasSanDiego
This is the only way I could get it to work also: uncheck "auto daylight savings adjustment", set to Mountain time (for us in Pacific Time) and set it back manually once we are back on PST. New firmward is needed for every release of the Command center.... not sure MB has the desire to make the fix. Thoughts?
TobiasSanDiego is offline   Reply With Quote
Old 04-02-2007, 08:50 AM   #8 (permalink)
I don't believe they do either. Its not like they are not aware of the pain!
Daylight Savings Time? Jayhawk General Mercedes-Benz 61 03-15-2007 10:58 PM
Daylight Savings Time - Forum Clock asianml BenzWorld Help 15 03-15-2007 09:12 AM
Time reset for daylight savings with NAV paulcars GL Class 7 03-12-2007 10:57 PM
Dumb Question - How do I reset the Clock for Daylight Savings Time? AndyFracica W164 M-Class 6 04-07-2006 05:21 AM
Amazing! Command GSP adjusts for daylight savings time automatically on my new CLK55! karl k W208 CLK Class 2 10-29-2001 06:13 PM
