Oil Leak easy fix - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-21-2009, 01:54 PM Thread Starter
tested2's Avatar
Date registered: Dec 2008
Vehicle: 2005 Mercedes Benz SLK350, 2000 Mercedes Benz E320 4Matic, 1994 Mercedes Benz E320
Oil Leak easy fix
I noticed that there was oil leaking down as I pulled my car out of the garage. I traced the oil leak to this round plastic piece on the driver side, topside, below the valve cover (see pics). I simply pry the piece out with a flathead and took it to my local MB dealer. They had the part available same day. Per the parts guy, this part apparently fails frequently so he told me not to be surprised if in a year, it starts to leak again. I installed the new part and no more leak.
I don't know what the part is for but here is the part #
000-998-56-90 EXPANSI F60F $6.56
Anyone know what this part is for?
ID:	216691   Click image for larger version
ID:	216692   Click image for larger version
tested2 is offline
post #2 of 3 (permalink) Old 11-21-2009, 09:14 AM
Carlo$'s Avatar
Date registered: Sep 2003
Vehicle: 97 SL500
thanks for the update.
Carlo$ is offline
post #3 of 3 (permalink) Old 11-21-2009, 04:04 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Its name in EPC is expansion plug on vacuum pump--epc contains footnote "see DTB S-B-01.30/23a regarding seepage from back of cylinder head."
EPC states "no longer applicable," which must mean later models don't use it.
In any event, I'd visit service department to get a chance to read the dtb, as if you're still under warranty they will for free apply the specified fix--which could be more than just replace this part. If not under warranty, you'd have to pay but it would still be nice to know the full details of the problem.
dtb=dealer technical bulletin
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
  Mercedes-Benz Forum > Mercedes-Benz Roadster Forums > R171 SLK-Class
    Selling an 07 CL550 - EASY FIX ramsey9000 C216 CL-Class 1 05-28-2008 04:02 PM
    Easy Fix rudedude W163 M-Class 10 09-19-2007 04:53 PM
    easy transmission fix or rebuild? wannakeepbenz W126 S,SE,SEC,SEL,SD,SDL Class 3 02-25-2006 10:31 PM
    Easy dim dash fix! Locry W124 E,CE,D,TD Class 0 09-16-2004 05:21 AM
    Oil leak @ head gasket 300E common problem/fix ? Guest (MBNZ) W124 E,CE,D,TD Class 3 06-07-2001 03:45 PM
